Export DXF Flat pattern in sub-assembly with iLogic
filippo.costantin3HZMT
Hi everyone,
I'm trying to export the dxf flat pattern of sheet metal part in assembly B that is place in Assembly A.
I tryed to use this rule, but it didn't run correcty.  Where is the error?
'IPT_OM_template is the name of Assembly in the rule
Sub Print_Assembly_IPT_DXF(IPT_OM_Template As String, pathOutputDXF As String)
	Dim oAsm As AssemblyDocument
	Dim oPenDoc as Document=ThisDoc.Document
	Dim AsmCompDefMainL0 As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	Dim AsmCompDefL1 As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	Dim OccurMainL0 As ComponentOccurrence
	Dim OccurL1 as ComponentOccurrence
	Dim AsmCompMainL0 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	Dim AsmCompMainL1 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	For Each OccurMainL0  In AsmCompDefMainL0.Occurrences
	Dim oOccNameL0 As String = OccurMainL0.Name
	Dim thisAssembly as AssemblyDocument = oOccNameL0
	Logger.Info("Apro assieme per DXF: " & oOccNameL0)
		'If OccurMainL0.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
			'For Each OccurL1 In OccurMainL0.SubOccurrences
			For Each doc In thisAssembly.AllReferencedDocuments
			Dim parsedPartName = doc.DisplayName
			Logger.Info("Selezionare parte da esportare in DXF: " & parsedPartName)
			if parsedPartName.Contains("CTG") Then
			Logger.Info("Ho selezionato la parte in CTG")
			Else
			Logger.Info("Ho selezionato la parte in lamiera")
			Dim sOut      As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=OUTER_PR​OFILE&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=INNER_PROFILE&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_BEND;IV_BEND_DOWN;IV_UNCONSUMED_SKETCH;IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;DIGI_MARKER_TOOL_1;DIGI_MARKER_TOOL_2"
			Dim component As SheetMetalComponentDefinition = doc.ComponentDefinition
			Dim PathDXF as String = pathOutputLamieraDXF & iProperties.Value(OccurL1, "Custom", "Nome_File")
			component.Unfold
			If System.IO.File.Exists(pathOutputDXF) = True Then
				System.IO.File.Delete(pathOutputDXF)
			End If
			component.DataIO.WriteDataToFile(sOut, PathDXF )
			Logger.Info("DXF " & SharedVariable("VPR_Codice") & " SUCCESS")
			component.FlatPattern.ExitEdit()
			doc.Close()
			End if
			Next
		'End if
	Next
End Sub
Ralf_Krieg
Hello
Which row of your Code is right? It seems you mixed two scripts together.
Is your script called by another script or should it run alone? I assume you calling this script by a Main sub. You will have to fill the string variables for template name and output path. There is a shared variable "VPR_Codice" and I assume it is set elsewhere. There is a variable "pathOutputLamieraDXF" used, but not set anywhere.
I've commented unused code.
Perhaps it will help, otherwise you have to post more details. It didn't run correctly is a little bit less information. :winking_face:
Sub Main()
	Dim IPT_OM_Template As String = ""	'<--- Fill missing Text
	Dim pathOutputDXF As String = ""		'<--- Fill missing Text
	Call Print_Assembly_IPT_DXF(IPT_OM_Template, pathOutputDXF)
End Sub
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	'Dim oPenDoc As Document=ThisDoc.Document
	Dim AsmCompDefMainL0 As AssemblyComponentDefinition = oAsm.ComponentDefinition 'ThisApplication.ActiveDocument.ComponentDefinition
	Dim AsmCompDefL1 As AssemblyComponentDefinition '= ThisApplication.ActiveDocument.ComponentDefinition
	Dim OccurL1 As ComponentOccurrence
	'Dim AsmCompMainL0 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	'Dim AsmCompMainL1 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
		Dim thisAssembly As AssemblyDocument = oOccNameL0
			'For Each doc In thisAssembly.AllReferencedDocuments
				If OccurL1.Definition.Type=ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
					Dim parsedPartName = OccurL1.ReferencedDocumentDescriptor.DisplayName ' doc.DisplayName
					If parsedPartName.Contains("CTG") Then
					Else
						Dim component As SheetMetalComponentDefinition = OccurL1.Definition
						'Dim PathDXF As String = pathOutputLamieraDXF & iProperties.Value(OccurL1, "Custom", "Nome_File")
						component.Unfold
						End If
						'component.DataIO.WriteDataToFile(sOut, pathDXF)
						component.DataIO.WriteDataToFile(sOut, pathOutputDXF )
						'component.Document.close()
					End If
				End If
			Next
		End If
	Next
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
thanks for your answer. Yes I use a Sub Main () for this code.
here the input that you need:
IPT_OM Template is the name of the assembly
Path_Output_DXF is the path of folder where I would save the DXF flat pattern of part.
SharedVariable("pathOutputLamieraDXF")     = SharedVariable("thisDocPath") & "\Output_DXF\"
I attached the assembly which I use for create the assembly.
 IPT_OM_Template
Ralf_Krieg
Hello
First, you posted only the iam, the included 3 ipt's are missing.
Anyway, I'll tried to modify the code so you could try to paste it in your assembly.
Sub Main()
	SharedVariable("VPR_Codice") = ""
	Dim IPT_OM_Template As String = ThisDoc.FileName(False) 'Filename of the assembly without file type extension (iam)
	Dim pathOutputDXF As String = ThisDoc.Path & "\Output_DXF\"  & IPT_OM_Template & ".dxf" 'Path to save the dxf to including filename of assembly and file type extension (dxf)
End Sub
		'Dim thisAssembly As AssemblyDocument = OccurMainL0.Definition.Document
				If OccurL1.Definition.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
					Else
						component.Unfold
						End If
						component.DataIO.WriteDataToFile(sOut, pathOutputDXF)
					End If
				End If
			Next
		End If
	Next
End Sub
R. Krieg
RKW Solutions
