Export certain parts on template excel
CGVJM6DF
CGVJM6DF
I tried to do it myself but not succeed...
I want to export on an excel template all the parts from all the subassemblies which has the iProperties
Left(iProperties.Value("Project", "Description"),13)
 And the list must beguine from Row 6, there are another info on the top of the sheet.
If there can be also the thumbnail that will be a +
Many thanks!
A.Acheson
Hi @CGVJM6DF
Can you attach the code you have worked on as it might just need some review. Where did you have trouble in making it work?
Can you explain currently how you are doing this process manually? Can you share the screenshots of the process?
If you only want to target the subassembly parts then you can open the subassembly exclusively and export the bom from there.
Regards
Alan
CGVJM6DF
thanks @A.Acheson
This is my code I work on, but only the first part it is working, til " 'Start listing parts from line6"
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oTemplate As String
oTemplate = "C:\Users\Cgv\OneDrive - KILDE A S Automation\Skrivebord\Packing List.xlsx"
Dim oPartTitle As String
oPartTitle = oDoc.ComponentDefinition.Document.PropertySets("Inventor Summary Information")("Title").Value
Dim oPartNumProperty As String
oPartNumProperty = ThisDoc.FileName(False)
Dim oPartRevNum As String
oPartRevNum = oDoc.ComponentDefinition.Document.PropertySets("Inventor Summary Information")("Revision Number").Value
Dim oData As String
oData = DateString
Dim oWSHnet As Object
Dim oUserName As String
oWSHnet = CreateObject("WScript.Network")
oUserName = oWSHnet.UserName
Dim xlApp As Object
Dim xlwb As Object
Dim xlws As Object
xlApp = CreateObject("Excel.Application")
xlwb = xlApp.Workbooks.Open(oTemplate)
xlws = xlwb.Worksheets(1)
xlApp.Visible = True
xlws.Cells(1, 3) = oPartNumProperty
xlws.Cells(3, 5) = "Created: " & oData
xlws.Cells(3, 3) = "List created by: " & oUserName
xlws.name = oPartNumProperty
' Start listing parts from line 6
Dim currentRow As Integer
currentRow = 6
' Get the BOM structure
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
' Iterate through the BOM rows
For Each oBOMRow As BOMRow In oBOM.BOMRows
    ' Check if the part description matches your condition
    Dim partDescription As String
    partDescription = oBOMRow.ComponentDefinitions(1).Document.PropertySets("Inventor Summary Information")("Description").Value
    ' Check if the description starts with "Bosch Profile"
    If partDescription.Length >= 13 AndAlso partDescription.Substring(0, 13) = "Bosch Profile" Then
        ' Export the part information to Excel
        xlws.Cells(currentRow, 1) = oBOMRow.ItemNumber
        xlws.Cells(currentRow, 2) = partDescription
        ' Add more columns as needed
        currentRow = currentRow + 1 ' Move to the next row
    End If
Next
' Save and close the Excel workbook
xlwb.Save
xlwb.Close
 We do not do it manualy, it is some thing we want to do.
Actualy the plan it is to do a "Paching list". A list whit all the bosch profile placed in the project, so we can order them all in one time, and as many are neded. Right now we have a problem whit that.
We would like it to be an excel sheet, on which there is more information about the project at the top. the name of the project, the name of the person who made the list, After the order arrives, the name of the person who took the order and the name of the person who will assemble the parts will be filled in by hand... (This is what I managed to do with this code)
Many thanks....
