Export BOM with Template
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Since Inventor R2022.1 you can use a template when you export a BOM view when using the interface. (Inventor 2023 Help | Assembly Enhancements | Autodesk)
It looks like these BOM export options are not included in the API (Inventor 2023 Help | BOMView.Export Method | Autodesk).
I tried to use the same way as mentioned in the Partlist export options (Inventor 2023 Help | PartsList.Export Method | Autodesk) But that did not work.
I know there are a lot of work arounds, but it would make life a lot easier if we can export BOM views directly into a excel template using the API.
Does anyone know if these options are supported?
