Event trigger missing from list (iPart or iAssembly Change Component)
Ethibaudeau
Ethibaudeau
I am looking to implement the Trigger "iPart or iAssembly Change Component".
However, the trigger is missing from the list of available triggers when a iPart .ipt is active. Weirdly, when an iAssembly .iam is active the trigger is available in the list.
bradeneuropeArthur
Put the i-part (alone) in a dummie (phantom) Assembly (iam) file, than it works!
Arthur Knoors
Autodesk Affiliations:
