Error on iLogic code - not obvious how to fix
RNDinov8r
RNDinov8r
Here is the code i have. I have commented out the error that I get when I go to run it. The intent is to run some iLogic to delete suppressed parts and assembly after running a form where the user would choose which options to include. Those options not used, would be suppressed, and then ultimately deleted.
Sub Main()
  Dim doc As AssemblyDocument
  doc = ThisApplication.ActiveDocument
  Dim acd As AssemblyComponentDefinition
  acd = doc.ComponentDefinition
  Call DeleteSuppressedComponent(acd.Occurrences)
End Sub
Sub DeleteSuppressedComponent(occs As ComponentOccurrences)
  Dim occ As ComponentOccurrence
  For Each occ In occs
     If occ.Suppressed Then
         occ.Delete
     Else
         Call DeleteSuppressedComponent(occ.SubOccurrences)
     End If
   Next
End Sub
'System.ArgumentException: The Parameter Is incorrect. (Exception From HRESULT: 0x80070057 (E_INVALIDARG))
   'at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   'at Inventor.ComponentOccurrence.Delete()
   'at ThisRule.DeleteSuppressedComponent(ComponentOccurrences occs)
   'at ThisRule.Main()
   'at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   'at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
DRoam
I was able to get this error by running your code on an assembly where an occurrence within a component pattern was suppressed. Could that be the issue for you?
If so, you could solve the issue by making sure the suppressed occurrence is not part of a pattern, and if it is, leave it alone. This tweak will do that:
	If Not occ.IsPatternElement Then
		occ.Delete
	End If
Else
End If
RNDinov8r
That looks like it. I had inadvertantly suppressed a part in a pattern. Thanks for the help
