Error in inserting Border into drawing through userform
Hello, still coming to grips with VBA, but managed to use the same code below to insert various title blocks through a userform. I have separated the code now to just generate on the click of a button to test out inserting a drawing border. I don't seem to be able to correct the errors in the code that are giving me a 'wrong number of arguments or invalid property assignment' while highlighting the oSheet.AddBorder at the end of the code. If anyone has any ideas how to fix I would highly appreciate this.
Sub GenerateButton_Click()
    'Get the active document.
    Dim oDrawDoc As Document
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Get the PropertySets object.
    Dim oPropSets As PropertySets
    Set oPropSets = oDrawDoc.PropertySets
    ' Obtain a reference to the desired border defintion.
    Dim oBorderDef As BorderDefinition
    Set oBorderDef = oDrawDoc.BorderDefinitions.Item("Default Border")
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Check to see if the sheet already has a border and delete it if it does.
    If Not oSheet.Border Is Nothing Then
        oSheet.Border.Delete
    End If
    Dim sPromptStrings(1 To 2) As String
    sPromptStrings(1) = "String 1"
    sPromptStrings(2) = "String 2"
    ' Add an instance of the border definition to the sheet.
    Dim oBorder As Border
    Set oBorder = oSheet.AddBorder(oBorderDef, , sPromptStrings)
    Unload Me
End Sub
JelteDeJong
According to the help page the AddBorder() function takes 2 arguments.
In your code i see 3:
                                   1      2        3
you could try:
Set oBorder = oSheet.AddBorder(oBorderDef, sPromptStrings)
Jelte de Jong
Blog: hjalte.nl - github.com
@JelteDeJong  Fantastic, that was it! Thank you very much for your quick response. Good reminder to also consult the help page thoroughly. Have marked it as solution accepted.
Kind Regards,
Joao
