Error in DetailDrawingView Object
So I'm trying to access a specific detail view of a part and change the size of boundary. Here's the code I have and it doesn't generate an error, but it also doesn't do anything and I'm not sure why. Is this an error in Inventor?
SyntaxEditor Code Snippet
Dim oDrawingViews As DrawingViews = ThisApplication.ActiveDocument.Sheets.Item(1).DrawingViews
For Each oView In oDrawingViews
    If oView.Name = "DETAIL B" Then
        MsgBox(oView.Name)
        oView.FenceRadius = 10
        InventorVb.DocumentUpdate()
    End If
Next
Also changing any property on the DetailDrawingViews Object doesn't do anything including even suppressing it or changing it's name.
Wow. Nevermind. I just changed the Item number to 3 (For the third drawing) and it worked....I'm curious why it didn't generate an error before because item 1 does not have a detail named that.
