Error in assembly
Error in assembly
steven.coxVCM6J
Error in assembly
steven.coxVCM6J
Hi all,
A while back I added an iLogic rule to toggle edit scope anytime I open(triggers after open) a part or assembly.  The rule works great in a single part or an assembly.
However, sometimes I get an error when opening assemblies that are populated with a lot of parts and sub-assemblies.
The code is:
Dim oDoc As Document = ThisDoc.Document
oModelStates = oDoc.ComponentDefinition.ModelStates
If oModelStates.MemberEditScope = MemberEditScopeEnum.kEditActiveMember Then
oModelStates.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
The error is this:
When I click ok, it pops up the next one until it cycles through all and then the assembly works fine.
The error appears to only be for documents that are using two different model states.  The part template has two models states but if they are not different than the primary, it does not seem to cause the error.
Any ideas as to how to make this not cause the error, or to suppress the error?
Please keep in mind I am not a coder...this is all new to me but quite useful.
Thanks, Steven
JelteDeJong
I expect your rule is having problems because you use the member document instead of the factory document. I wrote a blog post about this issue some weeks ago. You might want to check "Modelstates: iLogic and unexpected results" If my guess is correct then you could solve your issue by using
ThisDoc.FactoryDocument
' instead of
ThisDoc.Document
Your rule should look something like this:
Dim oDoc As Document = ThisDoc.FactoryDocument
Jelte de Jong
Blog: hjalte.nl - github.com
steven.coxVCM6J
This seems to have corrected the problem.
Thanks so much for the lesson!!
Steven
