ERROR COMING IN INVENTOR I-LOGIC
ashish.patilSP94R
ashish.patilSP94R
MY CODE IS BELOW
Try
    ' Ensure the active document is a PartDocument
    If TypeOf ThisDoc.Document Is PartDocument Then
        Dim oPartDoc As PartDocument
        oPartDoc = TryCast(ThisDoc.Document, PartDocument)
        If oPartDoc IsNot Nothing Then
            ' Specify the path to your custom drawing template
            Dim templatePath As String
            templatePath = "O:\PROJECT\INVENTOR LIBRARY\07-TEMPLATES\ATS_A3.idw"
            ' Create a new drawing document using the custom template
            Dim oDrawingDoc As DrawingDocument
            oDrawingDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templatePath)
            ' Verify if the drawing document is created successfully
            If oDrawingDoc Is Nothing Then
                MessageBox.Show("Failed to create the drawing document.")
                Exit Try
            End If
            ' Reference to the first sheet in the drawing
            Dim oSheet As Sheet
            oSheet = oDrawingDoc.Sheets.Item(1)
            ' Define the position for the base view
            Dim baseViewPosition As Point2d
            baseViewPosition = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
            ' Create base view with correct parameters
            Dim oBaseView As DrawingView
            oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc.ComponentDefinition, _
                baseViewPosition, 1, _
                ViewOrientationTypeEnum.kFrontViewOrientation, _
                DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
            ' Verify if the base view is created successfully
            If oBaseView Is Nothing Then
                MessageBox.Show("Failed to create the base view.")
                Exit Try
            End If
            ' Define the position for the projected views
            ' (Code for adding projected views...)
            ' Save the drawing to a specified path
            Dim savePath As String
            savePath = "O:\R&D\PRODUCT\CHANGES\030. A-KART WITH ROLLER CONVEYOR\3D DESIGN\OPTION 2\expansion joint related things\part1.idw"
            oDrawingDoc.SaveAs(savePath, False)
            MessageBox.Show("Drawing saved successfully at " & savePath)
        Else
            MessageBox.Show("Failed to cast active document as PartDocument.")
        End If
    Else
        MessageBox.Show("No active PartDocument found.")
    End If
Catch ex As Exception
    ' Display the error message
    MessageBox.Show("An error occurred: " & ex.Message)
End Try
bradeneuropeArthur
change this:
            oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc, baseViewPosition, 1, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Arthur Knoors
Autodesk Affiliations:
ashish.patilSP94R
oTopView = oSheet.DrawingViews.AddProjectedView(oBaseView, topViewPosition, 1, ViewOrientationTypeEnum.kTopViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
error in above line
@bradeneuropeArthur
bradeneuropeArthur
			 Dim topViewPosition As Point2d
            topViewPosition = ThisApplication.TransientGeometry.CreatePoint2d(20, 10)
			Dim oTopView As DrawingView
			oTopView = oSheet.DrawingViews.AddProjectedView(oBaseView, topViewPosition , DrawingViewStyleEnum.kHiddenLineDrawingViewStyle,1)
Arthur Knoors
