Announcements
Error changing part colour using VBA macro
isocam
isocam
Can anybody help?
Can somebody try the following VBA macro and tell me if they get an error on the line that contains the words "Set color"?
Public Function SetPartColour()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim color As ColorAssetValue
    Set color = oDoc.ActiveAppearance.Item("generic_diffuse")
    color.Value = ThisApplication.TransientObjects.CreateColor(255, 42,27) ' Red
End Function
I cannot get the macro to work. Does anybody know what's wrong.
Many thanks in advance!!!
Darren
HideoYamada
Your macro works and the color of part has been changed to red.
My system is...
- Windows 10 Pro 1903 64bit Japanese
- Inventor 2020.1 + Japanese language pack
Does the appearance of your part document have an item "generic_diffuse"?
Run the macro follows and check having it or not.
Public Sub Dump()
    Dim obj As Object
    For Each obj In ThisApplication.ActiveDocument.ActiveAppearance
        Debug.Print obj.Name
    Next
End Sub
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
matt_jlt
One thing that could cause it to throw an error is not having the correct appearance library active (the colour specified isn't in the active library). You may need to have an additional check to see if it's in there first or activate it then run the code again.
