Edit an existing Extrusion with Ilogic / vba
i have an existing Extrusion. I won't to change this from increase to cut out.
The name of the Extrsion is "Bohrungen"
SourceSource
Won't change to:
Hole thrue allHole thrue all
I have found a code that change the direction but i don't know to change the extrusion to Cut thrue.
Here is the code that i have now:
SyntaxEditor Code Snippet
Sub Main
 Dim extrude As ExtrudeFeature = TryCast(Feature.InventorFeature("Bohrungen"), ExtrudeFeature)
 Dim extent As DistanceExtent = TryCast(extrude.Extent, DistanceExtent)
If Noppen = True Then
 extent.Direction = PartFeatureExtentDirectionEnum.kPositiveExtentDirection
Else
extent.Direction = PartFeatureExtentDirectionEnum.kNegativeExtentDirection
End If
End Sub
I have tested with the kCutOperation, but i don't know how?
Sincerely
Replies (7)
JamieVJohnson2
I created a deck feature using this method.  The 'Operation' property of the ExtrusionDefinition of the ExtrusionFeature is what you are after aka ExtrudeFeature.Defnition.Operation
        Dim edDeck As ExtrudeDefinition = cdCarDeck.Features.ExtrudeFeatures.CreateExtrudeDefinition(skDeckProfile.Profiles.AddForSolid, PartFeatureOperationEnum.kNewBodyOperation)
                    edDeck.SetDistanceExtent(RowCar.DeckWidth * 2.54, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection)
                    Dim efDeck As Inventor.ExtrudeFeature = cdCarDeck.Features.ExtrudeFeatures.Add(edDeck)
                    extrusionDefinition.Operation=PartFeatureOperationEnum.kCutOperation 'and all other types
jvj
lzs013
ExtrudeDefinition Object
Operation
Read-write property that gets and sets the type of operation used to add the feature to the model. Valid inputs are kNewBodyOperation, kJoinOperation, kCutOperation, kIntersectOperation and kSurfaceOperation.
thank you for your help :slightly_smiling_face:
I only have a little problem.
I have change the Operation to kCutOperation, thats work fine, but i won't that there is no distance - only thrue all.
Can you help me again? Witch parameter is responsible for the "thrue" option?
Thanks :slightly_smiling_face:
Sincerely
lzs013
oEF = Feature.InventorFeature(“Bohrungen”)
oEF.Definition.SetThroughAllExtent(kNegativeExtentDirection)
oEF.Operation = kCutOperation
Thanks so much!
Now it works and i know why. Smiley Very Happy
Sincerely
HI there, I'm building a very simple illogic rule to turn features on and off based on a parameter. in one case I need to flip one of the extrude features. I'm unsure how to insert your code into my rule can you provide some guidance?
If Vertical_Divider = "Full" Then
Feature.IsActive("vDivider Base") = True
Feature.IsActive("vDivider Top") = True
ElseIf Vertical_Divider = "None” Then
(here I need to flip the vDivider Base asymmetric extrusion from 9,0.5 to 0.5,9)
Feature.IsActive("vDivider Top") = False
ElseIf Vertical_Divider = "Upper" Then
Feature.IsActive("vDivider Base") = False
End If
Thanks for your help
lzs013
vDividerBase=Feature.InventorFeature("vDivider Base")
vDividerBase.Definition.SetDistanceExtentTwo = 0.9
vDividerBase.Definition.SetDistanceExtent = 0.05
