Hi @DeptaM. I was able to translate all of your message to English, except one word (I don't know what "precerkovane" means).
{Good day,
if I have some components set as a reference, so in the drawing I display precerkovane and the contours are not done. In the dialog box on the Model tab, I need to set "Edges as part" and in the "Edge" field, override the value. I found that 50 is enough. I was looking for a rule that would run when I opened a new drawing and work for all views.
Thanks for the advice}
But I still do not fully understand what you are trying to do, or what you want. You may need to include more details about what you currently have, and more specific details about what you want to be able to do, and what you need help with. It sounds like you have an assembly document which contains some components, and you have set the BOMStructure of some of those components to reference. Then it sounds like you have a drawing document with views of the assembly and its components. But maybe you are not seeing the edges of those components that were set to reference within the drawing views, and you want to change that? And you want an iLogic rule to make this change happen for you? Does that sound about right?
This sounds similar to a post I made within the Inventor Ideas forum area. Take a look at that idea post and see if that is something like what you are wanting. If so, you can vote for it, so that hopefully it will be implemented in the future.
Wesley Crihfield
(Not an Autodesk Employee)
