Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
DXF edit by iLogic
1 REPLY 1
397 Views, 1 Reply
DXF edit by iLogic
Hi all,
I have an iLogic code that can export dxf of flat pattern from sheetmetal part.
Now I need to add external dimensions and write number of pieces automatically to this dxf.
Is there any way to do it?
Thanks for any advice.
My code is here:
	Dim FilePath As String
	FilePath = ThisDoc.Path & "\"
    If ThisApplication.ActiveDocument.ComponentDefinition.HasFlatPattern = False Then
       ThisApplication.ActiveDocument.ComponentDefinition.Unfold
    Else
	   ThisApplication.ActiveDocument.ComponentDefinition.FlatPattern.Edit
    End If
    Dim fSett As String
    fSett = "FLAT PATTERN DXF?AcadVersion=2000&InvisibleLayers=IV_UNCONSUMEND_SKETCHES;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_ARC_CENTERS;IV_TOOL_CENTER_DOWN;IV_TOOL_CENTER;IV_ARC_CENTERS;IV_TANGENT;IV_BEND;IV_BEND_DOWN&SplineTolerance Double 0.01&MergeProfilesIntoPolyline"
    Dim fSname As String
    fSname = FilePath & ThisDoc.FileName(False) & ".dxf"
ThisApplication.ActiveDocument.ComponentDefinition.FlatPattern.ExitEdit
1 REPLY 1
MechMachineMan
There is some code that might be close to what you want here:
https://forums.autodesk.com/t5/inventor-customization/export-idw-to-dxf/td-p/7539297/page/2
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
