There is actually another way to do this which will preserve all your dimensions and such. I'm not sure why I did not mention this in any of my earlier posts here. It seems like I have shown this method in a few other places in the forum before. Anyways, it uses the basic Copy/Paste system, combined with simulating some user inter face actions, such as selecting the active sheet, executing a command (copy), unselecting that sheet, then executing another command (paste). It includes some Inventor API code, but is a mix of using API and simulating user interface actions, so it will only work when that drawing is currently the 'active' document (currently fully visible on your screen at that moment). I even took it another step further and turned it into a separate Function routine, which will then retrieve and return the newly created copy of the active sheet for you. It is still not 'perfect', but pretty close. Of course it could still be developed further, such as adding the option to rename the new sheet, and/or repositioning the new sheet to a specific location, instead of just at the end of all existing sheets. As it is right now, the name of the new sheet will always start with "Copy of ", then the name of the original sheet, but with the new index number at the very end, because we can not control that index number. Also, if the active sheet (when you run the rule) contains views which have 'parent' views on another sheet, then it will show a small dialog telling you that the parent view must be copied along with the child view, due to the child view being dependent on the parent view, with only an OK button, so it will not copy that sheet.
Below is that code example:
Sub Main
Dim oInvApp As Inventor.Application = ThisApplication
Dim oDDoc As DrawingDocument = TryCast(oInvApp.ActiveDocument, DrawingDocument)
If oDDoc Is Nothing Then Return
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
Dim oNewCopySheet As Inventor.Sheet = CopySheet(oSheet)
Logger.Info("New Sheet's Name = " & oNewCopySheet.Name)
End Sub
Function CopySheet(oSheet As Inventor.Sheet) As Inventor.Sheet
If oSheet Is Nothing Then Return Nothing
Dim oDDoc As DrawingDocument = oSheet.Parent
Dim oInvApp As Inventor.Application = oSheet.Application
If oDDoc.Views.Count = 0 OrElse oDDoc IsNot oInvApp.ActiveDocument Then
Try 'it must be the 'active' document (visibly showing on your screen)
oDDoc = oInvApp.Documents.Open(oDDoc.FullDocumentName, True)
oDDoc.Activate()
Catch : End Try
End If
Dim oCmdMgr As CommandManager = oInvApp.CommandManager
Dim oCDs As ControlDefinitions = oCmdMgr.ControlDefinitions
oCmdMgr.DoSelect(oSheet)
oCDs.Item("AppCopyCmd").Execute()
oCmdMgr.DoUnSelect(oSheet)
oCDs.Item("AppPasteCmd").Execute()
Dim oNewSheet As Inventor.Sheet = oDDoc.Sheets.Item(oDDoc.Sheets.Count)
Return oNewSheet
End Function
One possible further developed version of that custom Function might look something like this:
Sub Main
'<<< if just copying one sheet, expect one Sheet to get returned >>>
'Dim oNewSheet As Inventor.Sheet = CopySheet(oSheet, 1)
'Logger.Info("New Sheet's Name = " & oNewSheet.Name)
'OR
'<<< if creating multiple copies, expect an array of Sheet to be returned >>>
Dim oNewCopies() As Inventor.Sheet = CopySheet(oSheet, 2, "Sheet 3", "Sheet 4")
Logger.Info("New Sheet Names:")
For Each oNewCopy In oNewCopies
Logger.Info(oNewCopy.Name)
Next
End Sub
Function CopySheet(ByVal oSheet As Inventor.Sheet, _
iNumberOfCopies As Integer, _
ByVal ParamArray NewSheetNames() As String) As Object
If iNumberOfCopies < 1 Then Return Nothing
Dim bMultipleCopies As Boolean = (iNumberOfCopies > 1)
Dim bNamesProvided As Boolean = ((NewSheetNames IsNot Nothing) AndAlso (NewSheetNames.Length > 0))
oDDoc.Activate()
Catch : End Try
End If
Dim oCopyCmd As ControlDefinition = oCDs.Item("AppCopyCmd")
Dim oPasteCmd As ControlDefinition = oCDs.Item("AppPasteCmd")
Dim oNewSheet As Inventor.Sheet = Nothing
Dim oNewSheets As List(Of Inventor.Sheet)
If bMultipleCopies Then oNewSheets = New List(Of Inventor.Sheet) 'initialize it
For i As Integer = 1 To iNumberOfCopies
oCopyCmd.Execute()
oPasteCmd.Execute()
oNewSheet = oDDoc.Sheets.Item(oDDoc.Sheets.Count)
If bNamesProvided Then
Try
oNewSheet.Name = NewSheetNames(i - 1)
Catch e As Exception
Logger.Error(e.ToString)
End Try
End If
If bMultipleCopies Then oNewSheets.Add(oNewSheet)
Next
If bMultipleCopies Then Return oNewSheets.ToArray
Return oNewSheet
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS)
Wesley Crihfield
(Not an Autodesk Employee)
