Sounds like you would have to use lines similar to these when setting up your view.
oViewOrientation = ViewOrientationTypeEnum.kCurrentViewOrientation
'Or
oViewOrientation = ViewOrientationTypeEnum.kSavedCameraViewOrientation
'Or if you already have another view to project from, you could try the
oViewOrientation = ViewOrientationTypeEnum.kArbitraryViewOrientation
'Other than that you would probably have to do a two view set-up using
oViewRotation = Pi/4
'Then turn the first view off
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" 👍.
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
- Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
- MessageBox, InputBox, and InputListBox Size & Format Options Click Here
- Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
- Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
- Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
- Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
- SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
(Not an Autodesk Employee)
