Drawing sketch line linked to work plane
malmal02122023
Message 1 of 32
malmal02122023
Could you help me please?
I am new in VBA ilogic
I would like to link a sketch line to work plane with offset 20 mm and use it to create section line.
I understand that the code shown below draws a line on the base view relative to its center.
Question: how can  build a line relative to the work plane located in the model and named A-A.
Thanks for advice
Dim SectionPoint_L As Point2d = oTG.CreatePoint2d(Left_X, oBaseView.Center.Y)
	Dim SectionPoint_R As Point2d = oTG.CreatePoint2d(Right_X, oBaseView.Center.Y)
	Dim SheetPoint_L As Point2d = SectionSketch.SheetToSketchSpace(SectionPoint_L)
	Dim SheetPoint_R As Point2d = SectionSketch.SheetToSketchSpace(SectionPoint_R)
	Dim SketchLine As Inventor.SketchLine = SectionSketch.SketchLines.AddByTwoPoints(SheetPoint_L, SheetPoint_R)
Replies (31)
Message 2 of 32
A.Acheson
Hi @malmal02122023
Your request does involve knowing the Inventor API in both assembly and drawing very well.
Linked in a previous post here is the below code. This will not work in your model but is a starting sample to learn what you need. Create a simple assembly with one occurrence. Place into the drawing this assembly. Manually check the workplane required can be made visible. If it can then run the code.
Sub Main
     SetWorkPlaneVisibilityFromAsm()
End Sub
Public Sub SetWorkPlaneVisibilityFromAsm()
    Dim oDrawingDoc As DrawingDocument
    oDrawingDoc = ThisApplication.ActiveDocument
    'Get referenced Assembly document
    Dim oAsm As AssemblyDocument
    oAsm = oDrawingDoc.ReferencedDocuments(1)
    'Get first occurrence, suppose it's a Part
    Dim oOcc As ComponentOccurrence
    oOcc = oAsm.ComponentDefinition.Occurrences(1)
    Dim oPartCompDef As PartComponentDefinition
    oPartCompDef = oOcc.Definition
    'Get YZ WorkPlane, suppose it's perpendicular to the view
    Dim oWP As WorkPlane
    oWP = oPartCompDef.WorkPlanes.Item("YZ Plane")
    'Create proxy object
    Dim oWPpx As WorkPlaneProxy
    Call oOcc.CreateGeometryProxy(oWP, oWPpx)
    'Set visibility
    Call oDrawingDoc.Sheets(1).DrawingViews(1).
                        SetVisibility(oWPpx, True)
End Sub
In order to dig down into the occurrence thst holds the workplane you will need to target the leaf occurrences of the assembly, this article will show you how
The below code will show you how to access leaf occurrences in your assembly. Open your assembly and run the code.
Sub Main
    GetPartOccurrences()
End Sub
Public Sub GetPartOccurrences()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
    For Each oOcc In oLeafOccs
        Logger.Info(oOcc.Name)
    Next
End Sub
Now integrate the two codes together. So you are not just looking at occurrence 1 but rather all occurrences. You will need further filtering to pick up the workplane by name. Hopefully this gets you started.
Regards
Alan
Message 3 of 32
malmal02122023
Ok, it is done.
Could you answer the question,  how to filter the name of work planes?
Sub Main()
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim oFirst_view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Please select the main view")
    If oFirst_view Is Nothing Then Exit Sub
    Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
    Dim occ As ComponentOccurrence
    If oFirst_view.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then
    Dim oComp As AssemblyDocument
    oComp = oFirst_view.ReferencedDocumentDescriptor.ReferencedDocument
    occ = oComp.ComponentDefinition.Occurrences.ItemByName("Skeleton test:1")
    Else
        Exit Sub
    Dim wp As WorkPlane
	Dim oSkeletonDoc As PartDocument
	oSkeletonDoc = occ.Definition.Document
    For Each wp In oSkeletonDoc.ComponentDefinition.WorkPlanes
        If wp.Name Like "1" Then
            Dim oProxy As WorkPlaneProxy
            Call occ.CreateGeometryProxy(wp, oProxy)
            Call oFirst_view.SetIncludeStatus(oProxy, True)
            Call oFirst_view.SetVisibility(oProxy, True)
    Next
End Sub
Best regards
Message 4 of 32
A.Acheson
It looks good, I didn't test it but it looks like everything is in the right place.
You can either directly find the name or do a wild card.
If wp.Name = "1" Then
Or
If wp.Name.Contains("1") Then
Regards
Alan
Message 5 of 32
malmal02122023
It’s clear that I can manually rewrite the value in the code. But I would like to call up a dialog box with work planes and select from it for their further creation.
Message 6 of 32
A.Acheson
In that case add the names to a listbox and present the user the list. Take the proxy creation outside the loop.
See help page here for list box
Dim materialList as New List (Of String)
materialList.add("steel")
material = InputListBox("Choose Part material", materialList, _ material, Title := "Part material", ListName := "Available Standard materials")
Regards
Alan
Message 7 of 32
malmal02122023
The code was changed as you describe
But I have error here. Could You help me please with this?
Dim wp.Name As String = InputListBox("Work planes found", wpList, "", "Select work plane", "work plane found")
Sub Main()
	    Dim oSheet As Sheet
    Else
        Exit Sub
    Dim wp As WorkPlane
		Dim wpList As New List(Of String)
		If wpList.Count = 0 Then Return
wpList.Add("work plane")
If String.IsNullOrEmpty(wp.Name) Then Return
		do
		''If wp.Name.Contains("AA") Then
		''End If
         Loop
    Next
End Sub
Message 8 of 32
A.Acheson
It looks like your trying to set/change the name which would not be your Intention.
Also you are no longer able to get  the workplane names and create its proxy in the lloop. Instead get the workplane object by its name outside the for loop and then proxy creation.
For
Each wp In oSkeletonDoc.ComponentDefinition.WorkPlanes wpList.Add("wp.Name")
Next Dim wpSel As String = InputListBox("Work planes found", wpList, "", "Select work plane", "work plane found") If String.IsNullOrEmpty(wpSel) Then Return wp = oSkeletonDoc.ComponentDefinition.WorkPlane(wpSel)
Regards
Alan
Message 9 of 32
malmal02122023
That is, I need to change
wpList.Add("wp.Name") to wpList.Add(wp.Name)
for the list to appear work planes name
But appear this error
No public WorkPlane member found for type PartComponentDefinition.
Message 10 of 32
A.Acheson
Apologies a few spelling errors, you caught the first and the second is that the object wp should be retrieved from the workplanes  collection. So add an s to workplane. The error message is correct.
Corrected line.
oSkeletonDoc.ComponentDefinition.WorkPlanes(wpSel)
Regards
Alan
Message 11 of 32
malmal02122023
It works.
But the ultimate goal is to create a section along the work plane. What are my next steps?
Thank you
Best regards
Message 12 of 32
A.Acheson
The next step is to get the drawing curve you just made visible/ included by using drawingcurvesenumerator.
Syntax
SectionDrawingView.DrawingCurves( [ModelObject] As Variant ) As DrawingCurvesEnumerator
And because you have only one Enumerator in your curve you can simply set it as item 1 to get the drawing curve.
Syntax
DrawingCurvesEnumerator.ItemIndex As Long ) As DrawingCurve
Once you have a drawing Curve you can get its start and end point as point 2d which you can then input into a view sketch and create a sketch line see API sample here written in vba. Convert as required.
Syntax
DrawingCurve.StartPoint() As Point2d
Regards
Alan
Message 13 of 32
malmal02122023
Something like this?
Sub Main()
	    Dim oSheet As Sheet
    Else
        Exit Sub
    Dim wp As WorkPlane
      wpList.Add(wp.Name)
Next
wp = oSkeletonDoc.ComponentDefinition.WorkPlanes(wpSel)
 Dim oSketch As DrawingSketch
            oSketch = oFirst_view.Sketches.Add
            Call oSketch.Edit
            Dim oStartPt As Point2d
            oStartPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).StartPoint.X, oSheet.Centerlines.Item(i).StartPoint.Y)
            Dim oStart As Point2d
            oStart = oFirst_view.SheetToDrawingViewSpace(oStartPt)
            Dim oEndPt As Point2d
            oEndPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).Name.EndPoint.X, oSheet.Centerlines.Item(i).EndPoint.Y)
            Dim oEnd As Point2d
            oEnd = oFirst_view.SheetToDrawingViewSpace(oEndPt)
            Dim oLine As SketchLine
            oLine = oSketch.SketchLines.AddByTwoPoints(oStart, oEnd)
            Call oSketch.ExitEdit
End Sub
Message 14 of 32
A.Acheson
I didn't dig into this much but first off typing in option explicit on to see how variables are bring up these errors.
Here is a quick  method to place a sketch line over the existing included workplane.
	Dim curve1 As DrawingCurve = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a drawing Curve").Parent
	Dim centerline As Centerline  = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCenterlineFilter, "Select a centerline")
	Dim drawView As DrawingView = curve1.Parent
	Dim sketch As DrawingSketch = drawView.Sketches.Add
	sketch.Edit()
	Dim line1 As SketchLine = sketch.AddByProjectingEntity(centerline)
	Dim line2 As SketchLine = sketch.SketchLines.AddByTwoPoints(line1.Geometry.StartPoint,line1.Geometry.EndPoint)
Regards
Alan
Message 15 of 32
malmal02122023
Thank you for help
Points 2d added and created line.
What is next?
Dim oStartPoint As Point2d
	oStartPoint = ThisApplication.TransientGeometry.CreatePoint2d(line2.Geometry.StartPoint.X, line2.Geometry.StartPoint.Y+1)
    Dim oEndPoint As Point2d
	oEndPoint = ThisApplication.TransientGeometry.CreatePoint2d(line2.Geometry.EndPoint.X, line2.Geometry.EndPoint.Y+1)
            oLine = sketch.SketchLines.AddByTwoPoints(oStartPoint, oEndPoint)
Message 16 of 32
A.Acheson
Well I guess dimensioning/ constraining your line is next. You should now have a solid sketchline overlapping the center line. How do you want the drawing to look? You could use the workplane directly to section or put in a dimension offset to use the sketchline. If you use a sketchline I believe you can make the workplane invisible once it's projected and this way the drawing isn't cluttered with a reference line. You will need to check if this all updates if for example you move the workplane or indeed the offset value. Maybe supply an image and list  of the constraints and dimensions and I can show you a method to get there. Otherwise looking on the forum for examples of linear sketchline dimesions and or here is a not to useful arc dimesion sample, it might give you an idea of the structure.
Example constraints could be vertical/horizontal constraint to the workplane center line start and endpoints this way the sketchline is the same length as the centerline. Maybe a parallel constraint between centerline and sketch line and finally an offset dimension.
Regards
Alan
Message 17 of 32
malmal02122023
The work planes have constant positions and will not be moved. But the sections should have offset from work planes.
I would like to be able to select the offset and depth of the section via a dialog box.
As for the sketch lines on the main view, they do not interfere because the main view will not be shown in the drawing, only the section views will remain there.
Best regards
Message 18 of 32
A.Acheson
Thanks for the information. Can you share an image of how you construct this sketch line constraints and dimensions manually? It will help you understand what constraints and dimensions you need to constrain the sketch line. After all the automation of this is purely based on how you the user want the sketch constrained. I might have a different workflow than you so it is important to figure out how you or your cad team does this in practice.
Regards
Alan
Message 19 of 32
malmal02122023
Please see scheme.
For example:
There are work planes named by 1, 2 and  3
Section line with offset 10 mm from wp '1' and ends of this line with offset 200 and 150 mm from wp '2' and wp '3'
Section looks down
Message 20 of 32
malmal02122023
Horizontal constrain  was added but I don't know how to add constraints for dimensioning (offset 10 and sides 200 and 150 mm as shown above ao scheme)
And How offseted line should be defined for secion line?
Sub Main()
	    Dim oSheet As Sheet
    Else
        Exit Sub
    Dim wp As WorkPlane
      wpList.Add(wp.Name)
Next
	sketch.Edit()
Call sketch.GeometricConstraints.AddHorizontal(oLine)
    sketch.ExitEdit
Dim oInsertionPoint As Point2d = oTG.CreatePoint2d((oFirst_view.Position.X + 10), (oFirst_view.Position.Y + 10))
Dim oSectionView As SectionDrawingView
oSectionView.SectionLineSketch = oLine
oSectionView = oSheet.DrawingViews.AddSectionView(oFirst_view, sketch, oInsertionPoint, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
oSectionView.SetDesignViewRepresentation(oSectionView.DesignViewRepresentation, True)
oSectionView.ReverseDirection
oSectionView.SectionDepth = 50/10
		oFirst_view.SetVisibility(oProxy, False)
  oFirst_view.SetIncludeStatus(oProxy, False)
End Sub
