Drawing sheet:1 and sheet:2 views scaling using Ilogic
manu.marjanen
manu.marjanen
How to write code as simply as possible.
To this drawing document "Sheet1"  "VIEW1" scale is "Parameter1" and
"Sheet2" "VIEW2" scale is "Parameter2"
mcgyvr
Dim oDwgDoc As Document
oDwgDoc = ThisApplication.ActiveDocument 'the current document
Dim oSheet As Sheet
oSheet = oDwgDoc.Sheets.Item(1) 'first sheet
Dim oView As DrawingView
oView = oSheet.DrawingViews.Item(1) 'first base view sheet 1
oView.Scale = Parameter1 'set drawing scale to parameter 1
oSheet2 = oDwgDoc.Sheets.Item(2) 'second sheet
Dim oView2 As DrawingView
oView2 = oSheet2.DrawingViews.Item(1) 'first base view sheet 2
oView2.Scale = Parameter2 'set drawing scale to parameter 2
manu.marjanen
Is this possible to do using names?
Sheet.Item(1) = "Sheet:1"
View.Item(1) = "View:1"
A.Acheson
Yes for the most part replacing the  number with the label name is possible.
Regards
Alan
A.Acheson
@manu.marjanen  The solved solution is the code posted by @mcgyvr
Regards
Alan
