Drawing creation automation using i logic
aswinsharingan
aswinsharingan
I having a assembly file in inventor. On running a rule in the assembly window I want the drawing to be created automatically with base view and isometric view. The drawing needs to pick a drawing template from a specific location
Can this be done with i logic . Please share your thoughts and help me on this.
romu51
There are a couple of posts here about it....
here is the code i use.
You might have to do some adjustment for position and sizes depending on the sheet sizes set in your template. It works well for me on A3.
make sure the part or assembly file is saved before running it.
Also orientate the model wisely.
Make sure the template path is right in the rule.
Sub Main()
	Dim oDrawingDoc As DrawingDocument
	Dim oSheets As Sheets
	Dim oView As DrawingView
	'capture the current active sheet
	Dim oCurrentNumber As Sheet
	Dim oPartDoc As Document
	Dim oSheet As Sheet
	Dim oTG As TransientGeometry
	Dim oView1 As DrawingView
	Dim oView2 As DrawingView
	Dim oView3 As DrawingView
	Dim oView4 As DrawingView
	Dim oView5 As DrawingView
	Dim oView6 As DrawingView
	Dim oViews As DrawingViews
	Dim TextSize_TB As Decimal
	Dim oScale As String
	Dim oPartsList1 As PartsList
	Dim View(0 To 5) As String
'GET SHEET METAL FLAT PATTERN EXTENTS LENGTH TO CALCULATE VIEW SCALES
'MessageBox.Show(iProperties.Value("Custom","FlatExtentsLength"), "Title")
'MessageBox.Show(iProperties.Value("Custom","FlatExtentsWidth"), "Title")
iProperties.Value("Custom", "Extents Length") = 1
iProperties.Value("Custom","Extents Width") = 1
extents_length = SheetMetal.FlatExtentsLength
extents_width = SheetMetal.FlatExtentsWidth
FLATPATTERNLENGTH = iProperties.Value("Custom","Extents Length")
FLATPATTERNWIDTH = iProperties.Value("Custom","Extents Width")
Dim sheetsize
sheetsize = MaxOfMany(FLATPATTERNLENGTH, FLATPATTERNWIDTH)
	'Ask to create drawing?
	AskCreateDrawing=MsgBox("Would you like to Create a drawing for this MODEL?"& Chr(10)&Chr(10)&"Ensure the front view is set", vbYesNo,"Drawing Selection")
	If AskCreateDrawing = vbYes Then
	    oPartDoc = ThisDoc.Document
	End If
	'Rotate Model to correct view
'	Dim oCamera As Camera
'	oCamera = ThisApplication.ActiveView.Camera
'	oCamera.ViewOrientationType = 10764 'Front View
'	oCamera.Apply
	'Define IDW Template File Location
	oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Users\RomPoteaux\...\Templates\Template.idw", True)
	oSheet = oDrawingDoc.Sheets.Item(1)
	   oSheet = oDrawingDoc.ActiveSheet
	   oViews = oSheet.DrawingViews
	   For Each oView In oViews
	       If oView.ScaleFromBase = False Then
	           oView.ScaleString = oScale
	       End If
	   Next
	'Limits of Drawing Border in cm
	X_Pos_Min = 4'0.6
	X_Pos_Max = 30'35.46
	Y_Pos_Min = 6
	Y_Pos_Max = 30'27.58
	vert_off = 1
	TextSize_TB = 0.2
	'Define 2d views
	oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min+((X_Pos_Max-X_Pos_Min)*0.25), Y_Pos_Min+((Y_Pos_Max-Y_Pos_Min)*0.25)+vert_off)' Bottom Left
	oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min+((X_Pos_Max-X_Pos_Min)*0.75), Y_Pos_Min+((Y_Pos_Max-Y_Pos_Min)*0.25)+vert_off)' Bottom Right
	oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min+((X_Pos_Max-X_Pos_Min)*0.25), Y_Pos_Min+((Y_Pos_Max-Y_Pos_Min)*0.75)+vert_off)' Top Left
	oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(35#, 12#)
	oPoint5 = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min+((X_Pos_Max-X_Pos_Min)*0.75), Y_Pos_Min+((Y_Pos_Max-Y_Pos_Min)*0.75)+vert_off)' Top Right
	oPointTLBL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.125), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.625)+vert_off)'
	'oPointTLTL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.125), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.875)+vert_off)'
	oPointTLBR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.375), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.625) + vert_off)'
	oPointTLTR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.375), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.875)+vert_off)'
	oPointTRBL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.625), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.625)+vert_off)'
	'oPointTRTL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.625), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.875) + vert_off)'
	oPointTRBR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.875), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.625) + vert_off)'
	oPointTRTR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.875), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.875)+vert_off)'
	oPointBLBL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.125), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.125)+vert_off)'
	'oPointBLTL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.125), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.375)+vert_off)'
	oPointBLBR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.375), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.125) + vert_off)'
	oPointBLTR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.375), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.375)+vert_off)'
	oPointBRBL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.625), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.125)+vert_off)'
	'oPointBRTL = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.625), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.375)+vert_off)'
	oPointBRBR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.875), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.125) + vert_off)'
	oPointBRTR = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos_Min + ((X_Pos_Max - X_Pos_Min) * 0.875), Y_Pos_Min + ((Y_Pos_Max - Y_Pos_Min) * 0.375)+vert_off)'
	'-----------------------Flat Pattern View Section-------------------------------------------------------------------------
'This is the code which adds the sheetmetal flat pattern default view:
' Create a new NameValueMap object
Dim oBaseViewOptions As NameValueMap
oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
'True = folded view
'False = flat pattern view
'oBaseViewOptions.Add("SheetMetalFoldedModel", False)
	'Set Base View
	If oPartDoc.DocumentType = kPartDocumentObject Then
		scale1 = get_size(oPartDoc, X_Pos_Max, X_Pos_Min, Y_Pos_Max, Y_Pos_Min)*3
	ElseIf oPartDoc.DocumentType = kAssemblyDocumentObject Then
		scale1 = get_sizeassy(oPartDoc, X_Pos_Max, X_Pos_Min, Y_Pos_Max, Y_Pos_Min)*3
	Else
		scale1 = 1 / 50
	End If
'  kDefaultViewOrientation = 10753
'  kTopViewOrientation = 10754
'  kRightViewOrientation = 10755
'  kBackViewOrientation = 10756
'  kBottomViewOrientation = 10757
'  kLeftViewOrientation = 10758
'  kIsoTopRightViewOrientation = 10759
'  kIsoTopLeftViewOrientation = 10760
'  kIsoBottomRightViewOrientation = 10761
'  kIsoBottomLeftViewOrientation = 10762
'  kArbitraryViewOrientation = 10763
'  kFrontViewOrientation = 10764
'  kCurrentViewOrientation = 10765
'  kSavedCameraViewOrientation = 10766
'  kFlatPivotRightViewOrientation = 10767
'  kFlatPivotLeftViewOrientation = 10768
'  kFlatPivot180ViewOrientation = 10769
'  kFlatBacksideViewOrientation = 10770
'  kFlatBacksidePivotRightViewOrientation = 10771
'  kFlatBacksidePivotLeftViewOrientation = 10772
'  kFlatBacksidePivot180ViewOrientation = 10773
	oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, scale1, kCurrentViewOrientation, kHiddenLineDrawingViewStyle)
	'oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oBaseView)
	'Bottom Right View
	oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint2, 32260)
	' Dims only placed if Left Hand View NOT active
	'oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView3)
	'Top Left View
	oView4 = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint3, 32260)
	'oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView4)
    'oView5 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint5, scale1, kFlatBacksideViewOrientation, kHiddenLineDrawingViewStyle), , , oBaseViewOptions)
	'oView5 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint5, scale1, kFlatBackViewOrientation, kHiddenLineDrawingViewStyle, , , oBaseViewOptions)
	''Top Right Hand ISO View
	oView6 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint4, scale1 * 0.75, kIsoTopLeftViewOrientation, kHiddenLineDrawingViewStyle)
	''*** NO Dims on this View ***
'Created by Ben Smeaton 16/05/2023, bensmeaton@gmail.com.
'On Error GoTo ClintBrown3D
''Code to Centre Dimensions - Adapted from the Inevntor API Sample by @ClintBrown3D
'	' a reference to the active drawing document
'    Dim oDoc As DrawingDocument
'    oDoc = ThisApplication.ActiveDocument
'    ' a reference to the active sheet & dimension
'    'Dim oSheet As Sheet
'    oSheet = oDoc.ActiveSheet
'    Dim oDrawingDim As DrawingDimension
'    ' Iterate over all dimensions in the drawing and center them if they are linear or angular.
'    For Each oDrawingDim In oSheet.DrawingDimensions
'        If TypeOf oDrawingDim Is LinearGeneralDimension Or TypeOf oDrawingDim Is AngularGeneralDimension Then
'            Call oDrawingDim.CenterText
'        End If
'    Next
''Code to Centre Dimensions - Adapted from https://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
'' Get the active document, assuming it is a drawing.
'    Dim oDrawDoc As DrawingDocument
'    oDrawDoc = ThisApplication.ActiveDocument
'    ' Get the collection of dimensions on the active sheet.
'    Dim oDimensions As DrawingDimensions
'    oDimensions = oDrawDoc.ActiveSheet.DrawingDimensions
'	    ' Get a reference to the select set and clear it.
'    Dim oSelectSet As SelectSet
'    oSelectSet = oDrawDoc.SelectSet
'    oSelectSet.Clear
'    ' Add each dimension to the select set to select them.
'    Dim oDrawDim As DrawingDimension
'    For Each oDrawDim In oDimensions
'        oSelectSet.Select(oDrawDim)
'    Next
'	Call ThisApplication.CommandManager.ControlDefinitions.Item("DrawingArrangeDimensionsCmd").Execute
'Return
'ClintBrown3D :
'MessageBox.Show("We've encountered a mystery", "Unofficial Inventor", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
' Run the external iLogic rule
'iLogicVb.RunRule("R:\Engineering\Autodesk\Customisation\iLogic\3-03AddOverallDims")
End Sub
Sub RunExternalRule(rulePath As String)
    Dim oPartDoc As PartDocument = ThisDoc.Document
	Try
    Catch ex As Exception
        ' Handle any errors that might occur
        MessageBox.Show("Error running the external iLogic rule: " & ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
    End Try
End Sub
Function New_Sheet (SheetName As Integer)
	oSheet = oDoc.Sheets(1)
	oSheet.Activate
	Dim oCommandMgr As CommandManager
	oCommandMgr = ThisApplication.CommandManager
	' Get control definition for the line command.
	Dim oControlDef As ControlDefinition
	 oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingNewSheetCtxCmd")
	' Execute the command.
	Try
	oControlDef.Execute
	Dim oSheet2 As Sheet
	oSheet2 = ThisDoc.Document.ActiveSheet
	oSheet2.Name ="Sheet:" & SheetName
	Catch
	End Try
End Function
Function get_size(oRefDoc As PartDocument, X_Pos_Max As Decimal, X_Pos_Min As Decimal, Y_Pos_Max As Decimal, Y_Pos_Min As Decimal)
	Try
		' Get the TransientBRep and TransientGeometry objects.
		Dim transBRep As TransientBRep = ThisApplication.TransientBRep
		Dim transGeom As TransientGeometry = ThisApplication.TransientGeometry
		' Combine all bodies in Part into a single transient Surface Body.
		Dim combinedBodies As SurfaceBody = Nothing
		For Each surfBody As SurfaceBody In oRefDoc.ComponentDefinition.SurfaceBodies
			If combinedBodies Is Nothing Then
				combinedBodies = transBRep.Copy(surfBody)
			Else
				transBRep.DoBoolean(combinedBodies, surfBody, BooleanTypeEnum.kBooleanTypeUnion)
			End If
		Next
		' Get the oriented mininum range box of all bodies in Part.
		' NOTE: "OrientedMinimumRangeBox" was added in Inventor 2020.3/2021.
		Dim minBox As OrientedBox = combinedBodies.OrientedMinimumRangeBox
		' Get length of each side of mininum range box.
		Dim dir1 As Double = minBox.DirectionOne.Length
		Dim dir2 As Double = minBox.DirectionTwo.Length
		Dim dir3 As Double = minBox.DirectionThree.Length
		' Sort lengths from smallest to largest.
		Dim lengths As New List(Of Double) From {dir1, dir2, dir3 }
		lengths.Sort
		Dim minLength As Double = lengths(0)
		Dim midLength As Double = lengths(1)
		Dim maxLength As Double = lengths(2)
		scale1 = (((Min(X_Pos_Max - X_Pos_Min, Y_Pos_Max - Y_Pos_Min)) / 2) * 0.33) / maxLength
		Return scale1
	Catch
		scale1 = 1 / 50
		Return scale1
	End Try
End Function
Function get_sizeassy(oRefDoc As AssemblyDocument, X_Pos_Max As Decimal, X_Pos_Min As Decimal, Y_Pos_Max As Decimal, Y_Pos_Min As Decimal)
	Dim oADoc As AssemblyDocument = oRefDoc
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	Dim oBox As Box = oADef.RangeBox
	Dim oMinP As Point = oBox.MinPoint
	Dim oMaxP As Point = oBox.MaxPoint
	Dim dX As Double = oMaxP.X - oMinP.X
	Dim dY As Double = oMaxP.Y - oMinP.Y
	Dim dZ As Double = oMaxP.Z - oMinP.Z
	Dim lengths As New List(Of Double) From {dX, dY, dZ}
	lengths.Sort
	Return scale1
End Function
Function view_label(oView As DrawingView)
	oView.ShowLabel = True
	oDescription = "<StyleOverride FontSize='0.35'><StyleOverride Underline='True'><Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride></StyleOverride>"
	oPartNumber = "<Br/><StyleOverride FontSize='0.35'><StyleOverride Underline='True'><Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride></StyleOverride>"
	oStringScale = "<Br/><StyleOverride FontSize='0.35'>(Scale <DrawingViewScale/>)</StyleOverride>"
	' oView.Label.FormattedText = oDescription & oPartNumber & oStringScale
End Function
