Here is a quick sample. It has drawing creation, view placement, and saving.
Dim DWGcreate As String = MsgBox ("Would You Like To Create A Drawing From This Part?" & vbLf & vbLf & "This Will Create a Base, Side & ISO View", vbYesNo, "Drawing Creation")
If DWGcreate = vbYes Then
Else
Return
Dim PartDoc As PartDocument = ThisDoc.Document
Dim TemplatePath As String = "Enter the file path of your template"
'No Template path provided.
Dim DrawingDoc As DrawingDocument = ThisApplication.Documents.Add(kDrawingDocumentObject, , True)
'Dim DrawingDoc As DrawingDocument = ThisApplication.Documents.Add(kDrawingDocumentObject,TemplatePath , True)
DrawingDoc.Activate()
Dim ActiveSheet As Sheet = DrawingDoc.ActiveSheet
Dim Scale As Double
'Scale Choices.
Dim ScaleList As New List (Of String)
ScaleList.Add("1/40")
ScaleList.Add("1/30")
ScaleList.Add("1/20")
Dim ScaleSel As String = InputListBox("Select one:", ScaleList, "", "iLogic", "Scale Choices")
If ScaleSel = "1/40" Then
Scale = 0.025
ElseIf ScaleSel = "1/30" Then
Scale = 0.0333333333
ElseIf ScaleSel = "1/20" Then
Scale = 0.05
Dim TG As TransientGeometry = ThisApplication.TransientGeometry
Dim Point1 As Point2d = TG.CreatePoint2d (12,15)
Dim BaseView As DrawingView = ActiveSheet.DrawingViews.AddBaseView(PartDoc, Point1, Scale, ViewOrientationTypeEnum.kTopViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Dim Point2 As Point2d = TG.CreatePoint2d(25, 15)
Dim RightView As DrawingView = ActiveSheet.DrawingViews.AddProjectedView(BaseView,Point2,DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
Dim Point3 As Point2d = TG.CreatePoint2d(35, 22)
Dim IsoView As DrawingView = ActiveSheet.DrawingViews.AddProjectedView(BaseView,Point3,DrawingViewStyleEnum.kShadedDrawingViewStyle)
Dim DrawingName As String = ThisDoc.Path & "\" & PartDoc.PropertySets.Item(3).Item("Part Number").Value & ".idw"
DrawingDoc.SaveAs(DrawingName,False)
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
