Draw a construction circle whose circumference is constrained by 3x selected points.
arron.craig
arron.craig
I'm essentially wanting a "3 point circle" from AutoCAD, however I can't do this project in AutoCAD.
I would like to be able to select 3x points and for the iLogic rule to draw a construction circle and coincident constraint it's perimeter to those three points. And then place a center point on the circles center.
Does anyone have some code kicking around that would do this?
Cadkunde.nl
Dim oDoc As PartDocument = ThisDoc.Document
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim p1 As Inventor.SketchPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select p1")
Dim p2 As Inventor.SketchPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select p2")
Dim p3 As Inventor.SketchPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select p3")
Dim oSketch As PlanarSketch = ThisApplication.ActiveEditObject
Dim oPoint1 As Inventor.Point2d = oTG.CreatePoint2d(p1.Geometry.X, p1.Geometry.Y)
Dim oPoint2 As Inventor.Point2d = oTG.CreatePoint2d(p2.Geometry.X, p2.Geometry.Y)
Dim oPoint3 As Inventor.Point2d = oTG.CreatePoint2d(p3.Geometry.X, p3.Geometry.Y)
Dim oCircle As Inventor.SketchCircle = oSketch.SketchCircles.AddByThreePoints(oPoint1, oPoint2, oPoint3)
oCircle.Construction = True
oCircle.CenterSketchPoint.HoleCenter = True
arron.craig
That works great, thankyou.
Any idea how to add a coincident constraint between the circle circumference and the 3 points?
Cadkunde.nl
oSketch.GeometricConstraints.AddCoincident(oCircle, p1)
oSketch.GeometricConstraints.AddCoincident(oCircle, p2)
oSketch.GeometricConstraints.AddCoincident(oCircle, p3)
arron.craig
Much appreciated. Thankyou
