Double click on Inventor icon sometimes opens two instances
danijel.radenkovic
danijel.radenkovic
Hello everyone,
Did someone have a problem with something like this?
I have found that some users had the same problem with AutoCAD, but in my case is Inventor 2016.
Furthermore, I have set using double click to open items (applications, folder ...) not a single click.
Regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
JamieVJohnson2
Windows can be set to open files and programs on one click.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
danijel.radenkovic
Please read carefulluy message that I wrote. I explicitly said: "I have set using double click to open items (applications, folder ...) not a single click.", so that information told you that I know the fact that single or double click opening can be adjusted on Windows.
Regards
Danijel
