does anyone know how to run an inventor macro in excel?
With solidworks I can write vba code in excel and when executing the macro, it does something in solidworks. Could you do the same with inventor?
Something like this:
another question
Does anyone know where I can find the official documentation for the api or ilogic?
WCrihfield
I, personally haven't tried running a Macro within Excel and have it effect Inventor, but it sounds doable, if you have the references set-up right, and get the Inventor Application object the right way.
As for your other question about official documentation...I think the following links are going to be along those lines:
Inventor API User's Manual
iLogic API Overview
Wesley Crihfield
(Not an Autodesk Employee)
A.Acheson
Here is how to set up excel VBA with the correct object.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/open-inventor-part-with-the-help-of-exc...
You will have to figure out how not to start an inventor app each time if there is already one active.
Regards
Alan
