Document.Close method not working after UserForm event CALL
karolis.s
karolis.s
Hello, looking for help to understand why Document Class Close method not working. It is called, but documents remain still opened and I can't change my project until I reboot Inventor Application.
Here is mine main function
Debug.WriteLine("All docs: " & InvApp.Documents.Count)
Debug.WriteLine("Visible documents: " & InvApp.Documents.VisibleDocuments.Count)
Dim oDocs As Documents = InvApp.Documents,
    visibleDocs = InvApp.Documents.VisibleDocuments,
    visibleDocsList As New List(Of String)
For Each oDoc As Document In visibleDocs
    visibleDocsList.Add(oDoc.FullFileName)
Next
For Each oDoc As Document In oDocs
    If Not visibleDocsList.Contains(oDoc.FullFileName) Then
        oDoc.Close()
Next
Debug.WriteLine("After close docs: " & InvApp.Documents.Count)
Here is event handler
Private Sub manufacturing_radio_btn_CheckedChanged(sender As Object, e As EventArgs) _
        Handles manufacturing_radio_btn.CheckedChanged
    If manufacturing_radio_btn.IsHandleCreated Then
        exportMfc = manufacturing_radio_btn.Checked
        DataGridView.Rows.Clear()
        DataGridView.Columns.Clear()
        AddColumns()
        AddRows()
End Sub
AddColumns function just take valid formats from my main class.
AddRows function Loops through each .idw file in given directory, opens it and sends to me valid sheets.
And again if event handler is not called, documents are closed properly, otherwise they remain open.
dalton98
Maybe try redefining the document before trying to close it?
Dim oDocs As DocumentsEnumerator = ThisApplication.Documents.VisibleDocuments
	oDoc = ThisApplication.Documents.open(oDoc.FullDocumentName, True)
	oDoc.Close
Next
