- Mute
- Permalink
- Report
Hello together,
how could I show and hide dockable windows via API?
Georg
Hello together,
Georg
Check the Programming Help for an example, methodes and properties, search for "DockableWindow Object".
This is a code example found in the help:
Sub DockableWindow()
Dim oUserInterfaceMgr As UserInterfaceManager
Set oUserInterfaceMgr = ThisApplication.UserInterfaceManager
' Create a new dockable window
Dim oWindow As DockableWindow
Set oWindow = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "TestWindowInternalName", "Test Window")
' Get the hwnd of the dialog to be added as a child
' CHANGE THIS VALUE!
Dim hwnd As Long
hwnd = 4851096
' Add the dialog as a child to the dockable window
Call oWindow.AddChild(hwnd)
' Don't allow docking to top and bottom
oWindow.DisabledDockingStates = kDockTop + kDockBottom
' Make the window visible
oWindow.Visible = True
End Sub
Eelco
Hello Eelco,
I got it already running. But how could I hide the Dockable window for example the viewcube?
Regards
Georg
If you named your dockable window with internal name "TestWindowInternalName" as was done in the above sample code, then this code will hide it:
Sub HideDockableWindow()
Set oWindow = oUserInterfaceMgr.DockableWindows("TestWindowInternalName")
oWindow.Visible = False
End Sub
Not sure what you mean by viewcube? :-s
Cheers,
Hello Adam,
I could hide my dockable window now. I found the solution to hide the viewcube:
ThisApplication.CommandManager.ControlDefinitions.Item("AppViewCubeCmd").Execute
How could I get the internalname from other add-ins?
Georg
Hi Georg,
have a look at the PrintCommandNames function here:
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Cheers,
