Do a "Add Numeric" Parameter to an .ipt.
b_ruijter
b_ruijter
I would like to know if it's possible to create a parameter via ilogic.
TomaszDabrowski
Hi.
You can use the AddByValue method. Few examples below:
Dim oDoc As PartDocument = ThisDoc.Document
oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("myParam", 15, UnitsTypeEnum.kMillimeterLengthUnits)
oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("myParam2", 15, "mm")
oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("myParam3", 15, "ul")
The rule will create 3 numeric user parameters. Keep in mind that the length parameters are initially defined in "cm", so you will probably need to divide your value
video
Tomasz Dąbrowski
Technical Support Specialist
Customer Technical Success
vpeuvion
Hi, can you try this :
Thisdoc.document.ComponentDefinition.Parameters.UserParameters.AddByExpression("AddNumeric", "2000", "mm")
Vincent.
