Disable drawing links to fea
andrew_canfield
andrew_canfield
Is there a way to unlink fea references to a 2016 drawing?
fea links.JPGsomething similar to:
https://forums.autodesk.com/t5/inventor-forum/break-unresolved-references/td-p/5631277
or a text output of the broken file paths?
Regards
Andrew
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield,
Try the video record which is attached in the below article link.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
andrew_canfield
Hello Chandra
I was hoping to find code.
The resolution box pops up 20 times & drilling through the assembly takes time.
It's annoying because the drawing doesn't need fea files.
Andrew
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield,
Try suggestions provide in below blog article.
http://adndevblog.typepad.com/manufacturing/2014/04/remove-missing-ole-links-using-referencedolefile...
Can you please provide sample drawing file to test? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
