DimensionArrows Options
bradeneuropeArthur
bradeneuropeArthur
How to do this with VBA or VB.net!
Arthur Knoors
Autodesk Affiliations:
bradeneuropeArthur
Found:
Public Sub Main()
Dim a As Application
 a = ThisApplication
Dim b As DrawingDocument
 b = a.ActiveDocument
Dim c As Sheet
c = b.ActiveSheet
Dim d As DrawingDimension
d = b.SelectSet.Item(1)
Dim oGeneralDim As GeneralDimension
oGeneralDim = b.SelectSet.Item(1)
oGeneralDim.ArrowheadsInside = False
End Sub
Arthur Knoors
