Diameter automation in drawing
edgar3M4N8
Message 1 of 1
edgar3M4N8
I am trying to do a code that do the following, but I am totally stuck in the part of deleting duplicated dimensions with lower quantities
1. Create diameter dimensions
2. Track dimension quantities
3. Label dimensions with quantities: (e.g., "3x ⌀50mm" if that dimension is used 3 times).
4.Delete duplicate dimensions with lower quantities:  (e.g., delete "1x ⌀50mm" & "2x ⌀50mm" if that dimension is used 3 times)
Below my code:
' Create a dictionary to store view names and their used dimension values with their counts
Dim viewUsedValues As New Dictionary(Of String, Dictionary(Of String, Integer))
Dim oSheet As Sheet = ThisApplication.ActiveDocument.ActiveSheet
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
' Initialize dictionary for all views
For Each oView As DrawingView In oSheet.DrawingViews
    viewUsedValues(oView.Name) = New Dictionary(Of String, Integer)
Next
' Process each view and create dimensions
    ' Temporary list to hold curves for dimension creation
    Dim tempCurves As New List(Of DrawingCurve)
    ' Collect curves that will be used for dimensioning
    For Each oCurve As DrawingCurve In oView.DrawingCurves
        If oCurve.CurveType = CurveTypeEnum.kCircleCurve Then
            tempCurves.Add(oCurve)
        End If
    Next
    ' Starting Y offset for dimension placement
    Dim yOffset As Double = oView.Top + 1
    Dim spacing As Double = 1 ' Adjust as needed for spacing between dimensions
    ' Create dimensions based on collected curves
    For Each oCurve As DrawingCurve In tempCurves
        ' Get the geometry intent from the curve
        Dim oIntent As GeometryIntent = oSheet.CreateGeometryIntent(oCurve)
        ' Define the point where the dimension should be placed
        Dim oPt1 As Point2d = oTG.CreatePoint2d(oView.Left + oView.Width, yOffset)
        ' Create the diameter dimension
        Dim oID As GeneralDimension = oSheet.DrawingDimensions.GeneralDimensions.AddDiameter(oPt1, oIntent, False, False, True)
        ' Get the dimension value in centimeters and convert to millimeters
        Dim dimValueInCm As Double = oID.ModelValue
        Dim dimValueInMm As Double = dimValueInCm * 10 ' Convert cm to mm
        Dim dimValue As String = dimValueInMm.ToString()
        ' Check if the value has been used already
        If viewUsedValues(oView.Name).ContainsKey(dimValue) Then
            ' Increment the count for this diameter value
            viewUsedValues(oView.Name)(dimValue) += 1
        Else
            ' Add the new diameter value to the dictionary with a count of 1
            viewUsedValues(oView.Name).Add(dimValue, 1)
        End If
        ' Update the dimension's text with the quantity and diameter symbol
        Dim quantity As Integer = viewUsedValues(oView.Name)(dimValue)
        Dim diameterSymbol As String = "⌀" ' Replace with your preferred symbol
        oID.Text.FormattedText = quantity.ToString() & "x " & "<DimensionValue/>"
        ' Increment the Y offset for the next dimension
        yOffset -= spacing
    Next
    ' Remove dimensions with lower quantities
    If viewUsedValues(oView.Name).Count > 0 Then
        Dim maxQuantity As Integer = viewUsedValues(oView.Name).Values.Max()
        For Each dimValue As String In viewUsedValues(oView.Name).Keys.ToList()
            If viewUsedValues(oView.Name)(dimValue) < maxQuantity Then
                ' Find and delete the dimension with this value
                For Each oID As GeneralDimension In oSheet.DrawingDimensions.GeneralDimensions
                    If oID.Text.FormattedText.Contains(dimValue & "x") Then
                        oID.Delete()
                    End If
                Next
            End If
        Next
    End If
Next
Replies (0)
