Announcements
Determine BOM Structure of a part from within a drawing
iogurt1
iogurt1
I have a drawing of an assembly. Inside the .iam I have a configurator that turns certain parts invisible AND turns their BOM Structure to Reference so they don't show up on the BOM anymore.
Now I am doing drawing automation. Is it possible to determine the BOM Structure of one of these parts from within my drawing so I can tell my code to only place a dimension if my part is
BOMStructureEnum.kNormalBOMStructure
but not when it is
BOMStructureEnum.kReferenceBOMStructure
 The reason it is still placing dimensions on invisible parts is that I am using Attribute Helper to create my attributes from work points. But they are still technically there even though the part is invisible.
Also, we don't want to work with Level Of Details, so I'm not looking for any suggestions involving suppression of parts.
Thanks!
Since the BOMStructureEnum can only be used within an assembly you could place a rule in the assembly that look like this:
SyntaxEditor Code Snippet
sArg1 = RuleArguments("Item Name")
If sArg1 <> " " And sArg1 <> "" Then
    If Component.InventorComponent(sArg1).BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
        SharedVariable("BOM Structure") = "Reference"
        MsgBox("Reference")
    Else MsgBox("Normal")
        SharedVariable("BOM Structure") = "Normal"
Then place a rule in the dwg that looks like this:
Dim map As Inventor.NameValueMap
map = ThisApplication.TransientObjects.CreateNameValueMap()
map.Add("Item Name", "Inlet Section")
iLogicVb.RunRule("Meter Assembly.iam", "Rule10", map)
AssyBOMStruct = SharedVariable("BOM Structure")
If AssyBOMStruct = "Normal" Then
    MsgBox("Run This Stuff")
Just change the variable names to fit your application and it should work!
