Detect thread standard from thread.xls
GeorgK
GeorgK
Hello together,
how could I get the thread standard from thread.xls? For example
oThreadStandard = "ISO Metrisches Profil" '"ISO Metric profile"
Sometimes I have the German or the english version. How could I distinguish it?
Thank you
Georg
j.brodersen
Hi Georg,
if you try to get hold of a parameter from the excel file you have to use the English name for the Sheet since it's named like this in the file it self!
E.g.
Sub Main
Dim Path As String = "C:\..."
MultiValue.List("Test") = GoExcel.CellValues(Path+"\Thread.xls", "ISO Metric profile", "A4", "A10")
End Sub
will insert the Size in to the parameter "Test"
Hope that this helps you
regards
Johann
Sergio.D.Suárez
Hello, try the following ilogic rule, maybe I can give light to your problem.
Dim oThreadTable As ThreadTableQuery = ThisApplication.GeneralOptions.ThreadTableQuery
For Each oType As String In oThreadTable.GetAvailableThreadTypes
	MessageBox.Show(oType)
Next
 I hope this can be useful, Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
GeorgK
Thank you very much. I can use both solutions.
