Detect Point Collision
Hello everyone,
I want to check if a point collides with any body in a multibody assembly.
I would like to make a random point in an(y) assembly:
dim ivApp as Inventor.Application
set ivApp = ThisApplication
dim ivDoc as AssemblyDocument
set ivDoc = ivApp.ActiveDocument
dim ivComp as ComponentDefinition
set ivComp = ivDoc.ComponentDefinition
Randomize
dim randomX as Double
randomX = rnd() * (ivComp.RangeBox.MaxPoint.X - ivComp.RangeBox.MinPoint.X)
dim randomY as Double
randomY = rnd() * (ivComp.RangeBox.MaxPoint.Y - ivComp.RangeBox.MinPoint.Y)
dim randomZ as Double
randomZ = rnd() * (ivComp.RangeBox.MaxPoint.Z - ivComp.RangeBox.MinPoint.Z)
dim ivTrans as TransientGeometry
set ivTrans = ivApp.TransientGeometry
dim randomPoint as Inventor.Point
set randomPoint = ivTrans.createPoint(randomX, randomY, randomZ)
Then I want to check if these coordinates collide with any body in the active assembly:
dim boolCollision as boolean
boolCollision = DoesPointCollide(randomPoint)
Function DoesPointCollide(ivPoint as Inventor.Point) as Boolean
'--> Insert code here <--
End Function
Can anyone help me with that? I don't know if Inventor provides a function that can return a true or a false with a point, or something comparable. Or where I can find a collection with a description of the body where I can deduct if there is a collision or not.
I do know that Inventor provides a collision detection in the animation, but I'm not sure if that would be something that I can use.
Kind regards
LukeDavenport
You're in luck Gilian. Once you've got the SurfaceBody object and the Point object you want to test, you can simply use SurfaceBody.IsPointInside.
Try the example below - just adjust the X Y Z values of 111, 222, 333 as you need in your code.
Hope this helps,
Luke
Dim oDoc As PartDocument = ThisApplication.ActiveEditDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSurfaceBods As SurfaceBodies = oDef.SurfaceBodies
Dim oTestPoint As Inventor.Point = ThisApplication.TransientGeometry.CreatePoint(111,222,333)
' Debug - create a workpoint
Dim oWP As WorkPoint = oDef.WorkPoints.AddFixed(oTestPoint, False)
For Each oSurf As SurfaceBody In oSurfaceBods
Select Case oSurf.IsPointInside(New Double(2) {oTestPoint.X, oTestPoint.Y, oTestPoint.Z })
Case ContainmentEnum.kInsideContainment
	MsgBox("Point is inside surface body: " & oSurf.Name)
Case ContainmentEnum.kOnContainment
	MsgBox("Point is ON surface body: " & oSurf.Name)
Case ContainmentEnum.kOutsideContainment
	MsgBox("Point is outside surface body: " & oSurf.Name)
End Select
Next
