Detect if selected part was created as as Custom Content Center
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
The macro below successfully detects if the current selected part is a content center part, but not if it was created with Content Center (As Custom). Example: a tube with the "Change Size" option enabled, saved as Custom.
I couldn't find any way to detect if it has the "Change Size" option enabled on the part. Any idea how to fix this?
On Error Resume Next
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oCount As Integer = oDoc.SelectSet.Count
Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane
If oDoc.DocumentType <> kAssemblyDocumentObject Or oCount = 0 Then Exit Sub
'If oDoc.SelectSet.Item(1).PropertySets.Item("ContentCenter").Item("IsCustomPart").Value = 1 then msgbox ("SIM")
If oCount > 1 Then
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyReplaceCmd").Execute2(True)
Exit Sub
End If
If oDoc.SelectSet.Item(1).IsiPartMember Or oDoc.SelectSet.Item(1).IsiAssemblyMember Then
Dim oNode As BrowserNode = oPane.GetBrowserNodeFromObject(oDoc.SelectSet.Item(1))
oNode.Expanded = True
Dim oTableNode As BrowserNode = oNode.BrowserNodes.Item(1)
oDoc.SelectSet.Clear
oTableNode.DoSelect
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyChangeComponentCmd").Execute
Exit Sub
End If
If oDoc.SelectSet.Item(1).DefinitionDocumentType <> kAssemblyDocumentObject Then
If oDoc.SelectSet.Item(1).Definition.IsContentMember Then
ThisApplication.CommandManager.ControlDefinitions.Item("CCV2ChangeSizeButton").Execute2(True)
Exit Sub
End If
End If
