DesignProject return exception when properties try change.
mikazakov
mikazakov
I did new option button to Project's Dialog. But when I try change the Properties of ActiveDesignProject in sub of event sink, Inventor API return exception. Inventor API does not change the Properties of DesignProject until the Project's Dialog is opened.
But Content Center AddIn can do changes to DesignProject with open Project's Dialog. How Content Center AddIn does it?
Why do I fails it?
I attached two screenshots and vb.net sample code:
Imports Inventor
Imports System
Imports System.Runtime.InteropServices
Module Module1
    'Идентификатор кнопки
    Private OptButton As ProjectOptionsButton
    Private InvApp As Application
    Sub Main()
        InvApp = GetInventorApplication()
        Const ID As String = "123"
        OptButton = InvApp.DesignProjectManager.AddOptionsButton(ID, "MyButton", "Option")
        'Привязка делегата
        AddHandler OptButton.OnClick, AddressOf OnClick
        'Цикл обработки сообщений
        System.Windows.Forms.Application.Run()
    End Sub
    'Процедура приемник события
    Private Sub OnClick(Context As NameValueMap)
        Try
            InvApp.DesignProjectManager.ActiveDesignProject.OldVersionsToKeep = 5
        Catch ex As Exception
            Console.WriteLine(":(((((((")
        End Try
    End Sub
    'Функция получения ссылки на Inventor
    Function GetInventorApplication() As Application
        Dim InvApp As Application
        Try
            'Попытка присоединится к загруженному в память Inventor
            InvApp = CType(Marshal.GetActiveObject("Inventor.Application"), Application)
            'Загрузка Inventor в память и присоединение к нему
            Dim InvType As Type = Type.GetTypeFromProgID("Inventor.Application")
            InvApp = CType(Activator.CreateInstance(InvType), Application)
            InvApp.Visible = True
        End Try
        Return InvApp
    End Function
End Module
woodstylee3
Hi, you appear to be trying to write to the active design project. I tend to find once files have been opened this is locked, and cannot be written to. It is also not always the file selected within the design project manager. Below is my code which is a bit messy but works, to get the currently selected project from the Context data passed with the button press..
Private Sub load_proj_options(Context As NameValueMap) Handles ss_OptButton.OnClick
 Dim x As Integer = 1
 Dim ds As String
 Dim dp As DesignProject = Nothing
 Do Until x = Context.Count
  If Context.Name(x) = "ProjectFileName" Then
     ds = Context.Item(x)
     x = x + 1
  End If
 Loop
 For Each design_project As Inventor.DesignProject In GlobalVars.m_inventorApplication.DesignProjectManager.DesignProjects
  If design_project.FullFileName = ds Then
     dp = design_project
  End If
 Next
 If Not (IsNothing(dp)) Then
   Dim n As New Proj_editor(dp)
      n.ShowDialog()
 End If
End Sub
mikazakov
The edit always blocked if show Project Dialog
I found in a different place that this limitation of API. The AddiIn of ContentCenter use other path (not AI API).
