Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Delete Bend Notes only in selected drawing view
3 REPLIES 3
chewy_robot
237 Views, 3 Replies
I have an ilogic rule started that is intended to delete flat pattern bend notes only in the selected flat pattern drawing view that is clicked on. I think I am close but can't quite get it. When I run this rule and click on the drawing view I want to delete the existing bend notes on (if any exist), it deletes the bend notes found on the entire drawing for all views. I want it so it only deletes the bend notes (if they exist) on the view that is selected after the rule is ran. How can I do this? Here is my current iLogic rule:
Imports System
Imports Inventor
Sub Main()
' Ensure you are in a drawing document
If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MessageBox.Show("This tool can only be run in a drawing file!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End If
Dim oDoc As DrawingDocument = CType(ThisApplication.ActiveDocument, DrawingDocument)
Dim oView As DrawingView = Nothing
Dim continueSelection As Boolean = True
While continueSelection
	Try
		' Use SelectionFilterEnum.kDrawingViewFilter for selecting drawing views
		oView = CType(ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a Drawing View to delete bend notes or ESC to exit."), DrawingView)
	Catch ex As Exception
		' User cancelled the selection or an error occurred
		MessageBox.Show("Selection cancelled or error occurred: " & ex.Message, "Selection Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
		continueSelection = False
		Exit While
	End Try
	If oView Is Nothing Then
		MessageBox.Show("No valid view selected.", "Selection Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Else
		' Directly delete bend notes in the drawing sheet of the selected view
		For Each oSheet As Sheet In oDoc.Sheets
			If oSheet Is oView.Parent Then
				Dim bendNotesToDelete As New List(Of BendNote)
				For Each oNote As DrawingNote In oSheet.DrawingNotes
					If TypeOf oNote Is BendNote Then
						bendNotesToDelete.Add(CType(oNote, BendNote))
					End If
				Next
				' Delete the collected bend notes
				For Each bn In bendNotesToDelete
					bn.Delete()
				Next
			End If
		Next
		MessageBox.Show("Bend notes deleted successfully from the selected view's sheet.", "Success", MessageBoxButtons.OK, MessageBoxIcon.Information)
		continueSelection = False ' Exit after processing
	End If
End While
End Sub
Labels (3)
3 REPLIES 3
You need to check the attached geometry is member of the selected view. Here is relevant part of your code.
        Dim oBendNote As BendNote = oNote
        If oBendNote.BendEdge.Parent Is oView Then
            bendNotesToDelete.Add(oBendNote)
        End If
    End If
Next
Thanks for the feedback! This helped me to get it to work. Here is the full code for anyone that may need it:
Imports System
Imports Inventor
Sub Main()
	Return
End If
	Try
		Exit While
	End Try
	Else
		' Collect bend notes associated with the selected view
		For Each oNote As DrawingNote In oView.Parent.DrawingNotes
				Dim oBendNote As BendNote = CType(oNote, BendNote)
				' Check if the bend note's associated edge's parent is the selected view
				End If
			End If
		Next
			bn.Delete()
		Next
		MessageBox.Show("Bend notes deleted successfully from the selected view.", "Success", MessageBoxButtons.OK, MessageBoxIcon.Information)
	End If
End While
End Sub
Plase use code sample block instead of plain text and keep indentation for better readability. You can find it in editor menu under </> button.
