Delete bend lines for spesific view
kairobert
kairobert
Hello. I am working with a drawing that i`m going to use as template. I want 2 unfolded views, one with bend lines, and one without. I want to delete bendlines at the view called "FLAT2". Is there someone here that could help me?
Andrii_Humeniuk
Hi @kairobert . If the line layer has the word "Bend" in its name, it becomes invisible. So make sure your bend line layers have the word "Bend" in their names, or change to your own.
Dim oDoc As Document = ThisDoc.Document
If Not TypeOf oDoc Is DrawingDocument Then Exit Sub
Dim oDDoc As DrawingDocument = oDoc
For Each oSheet As Sheet In oDDoc.Sheets
	For Each oView As DrawingView In oSheet.DrawingViews
		If oView.Name.Contains("FLAT2") AndAlso oView.IsFlatPatternView Then
			For i As Integer = 1 To oView.DrawingCurves().Count
				If oView.DrawingCurves()(i).Segments(1).Layer.Name.Contains("Bend") Then
					oView.DrawingCurves()(i).Segments(1).Visible= False
			Next i
	Next
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
FINET_Laurent
Hi @kairobert,
Maybe this code would do the trick ? The commented line (19) might be useful if the layer is not the default layer :
Sub main
	Dim doc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
	Dim s As Inventor.Sheet = doc.ActiveSheet
	Dim targetv As Inventor.DrawingView
	For Each v As Inventor.DrawingView In s.DrawingViews
		If v.Name = "FLAT2" Then
			targetv = v
			Exit For
	Next
	If targetv Is Nothing Then Exit Sub
	For Each dc As Inventor.DrawingCurve In targetv.DrawingCurves
		For Each dcs As Inventor.DrawingCurveSegment In dc.Segments
			If dcs.Layer.InternalName.Contains("1:Bend Centerline (ISO)")  Then dcs.Visible = False
			'If dcs.Layer.Name.Contains("Trait d'axe de pliage (ISO)")  Then dcs.Visible = False
		Next
	Next
End Sub
Does this suits your needs?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
