delete all suppressed parts in assembly (and sub assembly)
robbeRtek
robbeRtek
I need a script to delete all suppressed parts.
i've try to write the code (ilogic) :
Public
Function DeletesuppressedParts() Dim OAsmDoc As AssemblyDocument OAsmDoc = ThisApplication.ActiveDocument Dim oAsmDef As ComponentDefinition = OAsmDoc.ComponentDefinition oAsmDef.RepresentationsManager.LevelOfDetailRepresentations.Item("configuratie").Activate(True) For Each oOcc As ComponentOccurrence In OAsmDoc.ComponentDefinition.Occurrences If oOcc.Suppressed Then oOcc.Delete() Else Dim osubOcc As ComponentOccurrence If oOcc.SubOccurrences.Count > 0 Then For Each osubOcc In oOcc.SubOccurrences If osubOcc.Suppressed Then osubOcc.Delete() End If Next End If End If Next oAsmDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Master").Activate(True) End Function
The line : osubOcc.Delete() do nothing, here i need to delete a suppressed part in a sub assembly
(I am unable to remove parts in a sub assembly)
does anyone know a solution for this?
Ralf_Krieg
Hello
Try to iterate through all assembly levels using a recursive call:
Option Explicit on
Private Sub Main()
	Dim oAssDoc As AssemblyDocument = ThisDoc.Document
	Dim oAsmDef As ComponentDefinition = OAssDoc.ComponentDefinition
	DelSuppressedOccs(oAssDoc.ComponentDefinition.Occurrences)
End Sub
Private Sub DelSuppressedOccs(ByVal oOccs As ComponentOccurrences)
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oOccs
        If oOcc.Suppressed = True Then
            oOcc.Delete
        Else
                DelSuppressedOccs(oOcc.SubOccurrences)
    Next
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
robbeRtek
the idea is good, but it doen't work for parts in a sub assembly
i've found simialar code,  if i create a new rule and paste this code, the code works. it delete also the parts in the sub assembly
Sub Main()
  Dim doc As AssemblyDocument
  doc = ThisApplication.ActiveDocument
  Dim acd As AssemblyComponentDefinition
  acd = doc.ComponentDefinition
  Call DeleteSuppressedComponent(acd.Occurrences)
 ' MessageBox.Show("Message", "Title")
End Sub
Sub DeleteSuppressedComponent(occs As ComponentOccurrences)
  Dim occ As ComponentOccurrence
  For Each occ In occs
     If occ.Suppressed Then
         occ.Delete
     Else
         Call DeleteSuppressedComponent(occ.SubOccurrences)
   Next
End Sub
at this point i'll add the rule to the main code :
Sub main
	If RunRule = True Then
		Dim oTopAsmDoc As AssemblyDocument
		Try
			oTopAsmDoc = ThisApplication.ActiveDocument
			oTopAsmDoc.Save
		Catch
			MessageBox.Show("only assembly", "only assembly")
			Exit Sub
		End Try
		iLogicVb.RunRule("delete parts")
'		other functions
''		CopyComponents(ThisDoc.Path, ThisDoc.Document.DisplayName, "deuren")
''		iLogicVb.RunRule("Layout update")
		MessageBox.Show("end", "end code")
	RunRule = False
End Sub
'functions ...
the change of the parameter 'runrule', starts a other rule to delete all code and parameters when the main code is finish
If RunRule = False Then
	oAsmDef.RepresentationsManager.LevelOfDetailRepresentations.Item("configuratie").delete
	iLogicVb.Automation.DeleteAllRulesInDocument(OAsmDoc)
'delete parameters...
now i thought i was done , but after run the main code, the Suppressed parts in the sub assembly are still there, in the main they're gone....
'ive try to figure out why but i don't find the answer :
- i've delete al the functions so the only code left is the code in this post.
-if i suppress the (last)rule to 'delete code/parameters' and run the main code  (with only the funtion 'delete parts'), the code works, the suppressed parts in the sub assembly are gone (ok)
-now i unsuppesses the code to delete the rules (last rule)  and run again
the suppressed parts in the sub assembly are not gone ( not ok)
why??
Ralf_Krieg
Hello
I've tested my code multiple times and it works as expected all time. Comparing your code there's no difference in function.
If you have a suppressed subassembly and suppressed parts within and want to delete both, you better switch the order in recursion. You first need to dive into and delete subassembly afterwards.
Option Explicit on
Private Sub Main()
End Sub
            oOcc.Delete
    Next
End Sub
Is the last rule, deleting all rules an internal rule? If so, deleting a running rule...find the error. If the last rule is an external rule, I can think of changing the parameter triggers the last rule to run. As an event triggered rule, the rule changing the parameter is stopped right at the point of changing parameter run rule and waiting for last rule to finish. If so, a running rule could not be deleted.
That doesn't explain why suppressed parts in subassembly are still there. Is the deleteparts function embraced in a try catch statement catching errors silently?
R. Krieg
RKW Solutions
robbeRtek
we work still in inventor2019.
the reason of all the proplems is de lod,
delete a part or component with code, and then change the lod to master in the same run doesn't work correct, (the suppressed parts  in a sub assembly are still there or back again)
the solution is to save before change the lod to master.
but i'dont want to save that assembly again befor there is a copy (with other name). (similiar to ilogic design copy)
(i don't want change the origial assembly (delete some parts))
so first i need to copy  the hole assembly and then delete the parts, save, and change the lod to master and then delete al rules, lod, parameters...
