Deactivate Object Not Working
- Mute
- Permalink
- Report
Deactivation these after deactivate does not work
oTab = Nothing
When I start the Addin again the tab is still there after deactivate.
What is wrong in the code.
Public Sub SetupUserInterface(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean, ClientID As String)
oTab = oRibbon.RibbonTabs.Add(sName & "", "AknoorsMasterAddIn" & "", ClientID)
End Sub
Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
' This method is called by Inventor when the AddIn is unloaded.
' The AddIn will be unloaded either manually by the user or
' when the Inventor session is terminated.
' TODO: Add ApplicationAddInServer.Deactivate implementation
m_inventorApplication = Nothing
oTab = Nothing
System.GC.WaitForPendingFinalizers()
System.GC.Collect()
End Sub
Arthur Knoors
Autodesk Affiliations:
