custom view orientation or pauze loop
I have a code created to automatically to create drawings of my steel plates. But in some cases I need custom view orientation. How can I call?
Or can I stop my program. custom view orientation calls manually change and then restart?
below I have few bits that I tried but no success please
help my please I search there for a very long time to
Dim testFace As Face
Try
testFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCustomGraphicsFilter, "Select  face")
Catch ex As Exception
End Try
If (testFace Is Nothing) Then
Return
End If
'can I change this so that I can work manually and when I save the program resumed?
console.Writeline ("test")
console.readkey (n)
MessageBox.Show "Message", "Title"
This code not recognize ilogic?
THANK YOU :grinning_face_with_smiling_eyes:
I found the solution on my own
I made a macro and a userform  vba. And the result works. Solved
