Announcements
custom table -> align the text of table from top left
Hello
I have created Custom table on drawing but data displayed in row as centered align can any one please tell me how to display text start from left.
please check screenshot
bradeneuropeArthur
with coding or with inventor default?
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.ActiveSheet
Dim d As CustomTable
Set d = c.CustomTables.Item(1)
Dim co As Column
For Each co In d.Columns
co.ValueHorizontalJustification = kAlignTextLeft
Next
End Sub
Arthur Knoors
Hello
I want to do this with C# code
bradeneuropeArthur
translate it online
Arthur Knoors
