Hello Everyone,
Initially, I have a part file without custom properties. Here's the plan:
Create Custom Properties: Define three parameters (Prop1, Prop2, Prop3) with multi-list values using iLogic. I will provide the possible values for each property.
Design a Form: Develop a form incorporating these properties. Implement conditional logic (e.g., selecting a value for Prop1 will filter available options for Prop2, which in turn affects the choices for Prop3).
Automate iProperties Creation: Once the form is completed and 'Export' is selected for custom parameters, it will automatically generate the necessary iProperties.
- Integrate with Drawings: Ensure that these custom properties can be referenced in the drawing without being included in the title block.
Thank you for your attention.
Best regards,
Shubham Raturi
@WCrihfield, @Curtis_Waguespack , @Michael.Navara @AndrewHumiston
