Custom message form info center
RasmusBredal
RasmusBredal
Hi
It is possible to create custom messages through
communication center with Inventor API? - like remember to save.
bradeneuropeArthur
Not for the Communication Center:
But I use the Balloontip from Windows.
Public Sub Balloontip(StrTitle As String, StrText As String, Time As Integer)
        Dim NotIcon As System.Windows.Forms.NotifyIcon
        NotIcon = New System.Windows.Forms.NotifyIcon
        NotIcon.Icon = System.Drawing.SystemIcons.Information
        NotIcon.BalloonTipTitle = StrTitle
        NotIcon.BalloonTipText = StrText
        NotIcon.BalloonTipIcon = Windows.Forms.ToolTipIcon.Info
        NotIcon.Visible = True
        NotIcon.ShowBalloonTip(Time)
    End Sub
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
bradeneuropeArthur
Or you could use the inventor built in as you needed!
This will completely fulfill your needs I think?
Dim a As Application
Set a = ThisApplication
Dim b As Balloontip
Set b = a.UserInterfaceManager.BalloonTips.Add("String Name", "String Title", "Watch out")
b.Display
Arthur Knoors
