Creating scenes in presentation file and linking them to view representations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have a pretty complicated assembly that I am creating assembly documents for and I have the assembly steps set up in different view representations in my assembly. I want to create a presentation file (.ipn) in the same directory as the assembly and then create a scene that is linked to each view representation in the assembly. I will go in an manually make the tweaks the the scenes and take whatever snapshots I want. After this I want to create an assembly drawing in the same directory as the presentation file and then create a sheet for every scene in the presentation file. After the sheets are created, I want to go in and add a base view for every snapshot in the scene to the scene's respective sheet.
The only thing that is holding me back is:
- Creating a new scene in a presentation file and pointing it to a design representation in an assembly
I have searched the API docs but I haven't found anything regarding this.
I will post the entire code if anybody could help me out with the above step.
Thanks for your time.
Cheers,
Michael
