Create part subassembly
I want to create a new part in the active subassembly? This is the code i have so far:
Dim oDoc As Document
oDoc = ThisApplication.ActiveEditDocument
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	Dim oNewPart As PartDocument
	'set to millimeter
    oNewPart = ThisApplication.Documents.Add(kPartDocumentObject,ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject)  , False)
	oNewPart.UnitsOfMeasure.LengthUnits =UnitsTypeEnum.kMillimeterLengthUnits
	Dim oNewPartDef As PartComponentDefinition
    oNewPartDef = oNewPart.ComponentDefinition
	Dim oMartrix As Matrix
    oMatrix = ThisApplication.TransientGeometry.CreateMatrix()
	Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(0,0,0))
    'add the new part to the assembly
    Dim oNewOcc As ComponentOccurrence
	oNewOcc = oDoc.ComponentDefinition.Occurrences.AddByComponentDefinition(oNewPartDef,oMatrix)
	oNewOcc.Edit
End If
ianteneth
Hi! I think a little more information would help. I assume this code is not working? Where does the code fail? What else is needed in the code to achieve what you want?
