Create Macro to create assembly file, and place currently open part file into it grounded at origin.
C_Haines_ENG
Message 1 of 9
C_Haines_ENG
As the title says, I need to create about 2000 assembly files from parts so I can insert all of the hardware that goes into it, Is it possible to write a macro to create an assembly file and place the current part file I have open into it and grounded at the origin.
Replies (8)
Message 2 of 9
Michael.Navara
This is what do you request. But you can create assembly occurrence by file name instead of ComponentDefinition.
Sub main
	Dim part As PartDocument = ThisDoc.Document
	Dim asmTemplate As String = "" 'Your assembly template file here
	Dim visible As Boolean = True
	Dim asm As AssemblyDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, asmTemplate, visible)
	Dim position As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
	Dim occ As ComponentOccurrence = asm.ComponentDefinition.Occurrences.AddByComponentDefinition(part.ComponentDefinition, position)
	occ.Grounded = True
End Sub
Message 3 of 9
C_Haines_ENG
This doesn't seem to work with Macros, giving me a Syntax error.
Message 4 of 9
Michael.Navara
Message 5 of 9
C_Haines_ENG
I am looking to get it to run with a keypress, are you able to convert it to VBA?
Message 6 of 9
Michael.Navara
Sub IC_11231683()
    Set part = ThisApplication.ActiveDocument
    asmTemplate = "" 'Your assembly template file here
    visible = True
    Set asm = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, asmTemplate, visible)
    Set position = ThisApplication.TransientGeometry.CreateMatrix()
    Set occ = asm.ComponentDefinition.Occurrences.AddByComponentDefinition(part.ComponentDefinition, position)
    occ.Grounded = True
End Sub
Message 7 of 9
C_Haines_ENG
Honestly, Thank you So much you're saving me hours of work. Id hate to ask further but do you know if its possible to transfer the iProperty description of the part file to the assembly file? Aswell, is it possible to name it whatever the Part Number is?
Message 8 of 9
Michael.Navara
Sub IC_11231683()
    asmTemplate = ThisApplication.FileManager.GetTemplateFile(kAssemblyDocumentObject, kMetricSystemOfMeasure) 'Your assembly template file here
    visible = True
    occ.Grounded = True
    Dim designTrackingProperties As String
    designTrackingProperties = "{32853F0F-3444-11D1-9E93-0060B03C1CA6}"
    Dim partNumber As String
    partNumber = part.PropertySets(designTrackingProperties)("Part Number").value
    Dim description As String
    description = part.PropertySets(designTrackingProperties)("Description").value
    'Set DisplayName to unsaved file becomes the default file name of this file.
    asm.PropertySets(designTrackingProperties)("Description").value = description
    asm.DisplayName = partNumber
End Sub
Message 9 of 9
C_Haines_ENG
This is Perfect! You're amazing!
