Announcements
Create derived part: to bring the one or more part document into the current doc
RoyWickrama_RWEI
RoyWickrama_RWEI
Could some one help me on the following - Thanks.
DRoam
The following code will derive in multiple parts, whose filenames are specified under the "Specify parts to derived in" section. You could instead use a loop of InputBoxes to specify part filenames, or some other method -- I wasn't sure what to do because you didn't provide any details about how you want to specify the parts to be derived in.
Dim ruleTitle As String = "Derive Multiple"
' Get current part document (the "recipient" part)
Dim partDoc As PartDocument = ThisDoc.Document
' Set reference to Derived Part Components manager for recipient part
Dim derPartComps As DerivedPartComponents = partDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
' Specify parts to derived in (the "source" parts)
Dim sourcePartPaths As New List(Of String)
sourcePartPaths.Add("C:\...\PartToDeriveIn.ipt") ' <-- Change to path of the part you want to derive in.
sourcePartPaths.Add("...") ' <-- Repeat for each desired source part.
If sourcePartPaths.Count > 0 Then
	' Start transaction
	Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(partDoc, ruleTitle)
	' Derive in each specified part
	Dim failedParts As New List(Of String)
	For Each sourcePartPath As String In sourcePartPaths
		If IO.File.Exists(sourcePartPath) Then
			Dim derivedPartDef As DerivedPartUniformScaleDef
			Try
				' Create definition for derived part.
				derivedPartDef = derPartComps.CreateUniformScaleDef(sourcePartPath)
			Catch ex As Exception
				failedParts.Add("- '" & sourcePartPath & "': Error creating derive definition: '" & ex.Message & "'")
				Continue For
			End Try
			Try
				' Set up the Derive.
				'derivedPartDef.IncludeAll
				'derivedPartDef.IncludeAllSolids = True
				failedParts.Add("- '" & sourcePartPath & "': Error setting up derive: '" & ex.Message & "'")
				Continue For
			End Try
			Try
				' Create Derive feature.
				derPartComps.Add(derivedPartDef)
				failedParts.Add("- '" & sourcePartPath & "': Error creating derive feature: '" & ex.Message & "'")
			End Try
		Else
			failedParts.Add("- '" & sourcePartPath & "': File does not exist")
	Next
	If failedParts.Count = sourcePartPaths.Count Then
		trans.Abort
	Else
		trans.End
	If failedParts.Count > 0 Then
		MessageBox.Show("The following parts could not be Derived:" & vbCr & vbCr & String.Join(vbCr, failedParts), ruleTitle, MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
Else
	MessageBox.Show("Must provide at least one Part to derive in.", ruleTitle, MessageBoxButtons.OK, MessageBoxIcon.Information)
RoyWickrama_RWEI
Thanks a lot for the reply.
This is the kind of rule I could never see in the forum.
It works great and is a great great help.
It brings all the entities in to the current document.
I do not like to bother you.
But, could you help me to get the following Derived Style dialog box. Thanks a lot.
DRoam
Hi @RoyWickrama_RWEI, take a look at this page in the API documentation: DerivedPartDefinition Object. It covers how to set all of those configurations by applying them to the "derivedPartDef" object.
RoyWickrama_RWEI
Thanks for the guide line.
I will be able to get this around.
Will let you know the progress.
RoyWickrama_RWEI
Thanks DRoam.
I keep tailoring the rule to my needs. (rule attached here to)
Case - 1:
Currently, I have the following issue: i.e. the derived does not appear in the browser unless I close and reopen.
I appreciate receiving some help.
Case-2:
Still I could not figure out how to invoke the Derive Part Derive Style dialog box.
