Announcements
Create base view specific sheet
NachitoMax
NachitoMax
Hi
When creating a base view on a sheet by using a drawing template, can you select a a specific sheet from the template to add the view to?
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
dgreatice
Yes you can. with this code:
Dim oDWGdoc as DrawingDocument
oDWGDoc = ThisApplication.ActiveDocument
Dim oSht as Sheet
'oSht = oDWGDoc.sheets.item(1)  'With index, result get sheet:1 ; or
'oSht = oDWFDoc.sheets.item("test:2") ' with name of sheet  ; pick one
'next you're code
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
