Create an ilogic rule for round up length
eladm
Message 1 of 24
eladm
Hi All
I need an ilogic rule for  tube and pipe length
for example:
for each pipe when the length (QTY column ) is between 0-4.99 m another column (Item QTY for example) the value will be : 5m .  when the length between 5-9.99 m the value will be 10m , when the length between 10-14.99 m the value will be 15m . If the length will be at inch can it convert to m , and than change the other column value ?
Regards
  • rule
Replies (23)
Message 2 of 24
Michael.Navara
You don't need iLogic for this. You can define new parameter with the following expression. Then you can set this parameter to BOM.
ceil(Length / 5 m) * 5 m
Message 3 of 24
nstevelmans
Hi, maybe this can be start.
 Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
        Dim oSheet As Sheet = oDrawDoc.ActiveSheet
        Dim oPartslist As PartsList = oSheet.PartsLists.Item(1)
        Dim rows As PartsListRows = oPartslist.PartsListRows
        Dim row As PartsListRow = Nothing
        Dim Columns As PartsListColumns = oPartslist.PartsListColumns
        'Dim QTY As PartsListColumns = Columns.Item("QTY")
        For Each row In rows
            Dim QTYValue As String = (row.Item("QTY").Value)
            If QTYValue.Contains("in") Then
                Dim cleanString As String = Replace(QTYValue, "in", "")
                Dim QTYValueNew As Double = CDbl(Val(cleanString)) '// Val do hard
                QTYValueNew = Math.Round((QTYValueNew * 25.4) / 1000, 2)
                row.Item("QTY").Value = CStr(QTYValueNew & " " & "m")
                row.Item("QTY").Static = True
                If QTYValueNew < 5 Then
                    row.Item("ITEM QTY").Value = CStr(5 & " " & "m")
                If QTYValueNew >= 5 AndAlso QTYValueNew < 10 Then
                    row.Item("ITEM QTY").Value = CStr(10 & " " & "m")
                If QTYValueNew >= 10 AndAlso QTYValueNew < 15 Then
                    row.Item("ITEM QTY").Value = CStr(15 & " " & "m")
        Next
Message 4 of 24
eladm
Hi
The rule didn't do anything
I need that in the part list :
if the total length of the pipe (after add 5%) the value will be changed to 1,2,3 ...
If the length is 0 – 4.99m the value will need to be 1
If the length is 5 – 9.99m the value will need to be 2
If the length is 10 – 14.99m the value will need to be 3 ...
*** not change the value of the coupling ***
regards
Message 5 of 24
nstevelmans
Hi, try this one
        Dim Partslistrows As New List(Of PartsListRow)
                Dim QTYValueNew As Double = CDbl(cleanString)
                QTYValueNew = Math.Round(QTYValueNew * 25.4, 2)
                row.Item("QTY").Value = CStr(QTYValueNew)
            If QTYValue.Contains("mm") Then
                Dim cleanString As String = Replace(QTYValue, "mm", "")
                QTYValueNew = Math.Round(QTYValueNew, 2)
        Next
            Dim Valuestart As Double = 0
            Dim value2 As Double = 5000
            If row.Item("QTY").Static = True Then
                Dim count As Integer = 2
                For i = 1 To 1000
                    Dim QTYValueNew As Double = CDbl(QTYValue)
                    If QTYValueNew < 5000 Then
                        row.Item("QTY").Value = CStr(1)
                    If QTYValueNew >= value2 AndAlso QTYValueNew < value2 * 2 Then
                        row.Item("QTY").Value = CStr(count)
                    value2 = value2 + 5000
                    count = count + 1
                    If value2 > QTYValue Then
                        Exit For
                Next
        Next
Message 6 of 24
eladm
Hi
Can you add 5% of the length before change  the value ?
Can you add : if the unit is at meter ? ( is the rule only for the unit at inch or mm ? )
If the length is change after run the rule , I need manually to uncheck the static value(in the part list) and rerun the rule ?
regards
Message 7 of 24
nstevelmans
Hi,  I Modified the code and added the issues
Works with mm and inches
You can  update the Assy and rerun the rule
5% tol added
            row.Item("QTY").Static = False
        Next
				QTYValueNew = QTYValueNew + (QTYValueNew / 20)
        Next
                For i = 1 To 1000
                    count = count + 1
                        Exit For
                Next
        Next
If this answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Message 8 of 24
eladm
Hi
Can you add a code in the rule if the pipe's unit is already in meter ? (add to the inch and the mm)
regards
Message 9 of 24
nstevelmans
Hi, Added the m request.
			  If QTYValue.Contains("m") Then
                Dim cleanString As String = Replace(QTYValue, "m", "")
                QTYValueNew = Math.Round(QTYValueNew * 1000, 2)
        Next
                For i = 1 To 1000
                    count = count + 1
                        Exit For
                Next
        Next
Message 10 of 24
eladm
Hi
The result take now a more time to get the result , and the result is wrong
I got this :
the mm and inch  is give wrong result  , you also delete the /20 - is this the 5% ?
Why at m you multiple by 1000 ?
but here a test :
if I rerun the rule the result will be 1 , no matter
regards
Message 11 of 24
nstevelmans
Hi, conditional statements where wrong,
QTYValueNew = QTYValueNew + Math.Round(QTYValueNew / 20) is the 5%
QTYValueNew = Math.Round(QTYValueNew * 1000, 2) roundup is based on mm so I convert m to mm
try this one
        Next
                QTYValueNew = QTYValueNew * 25.4 'convert in to mm
                QTYValueNew = Math.Round(QTYValueNew + (QTYValueNew / 20), 2) 'add 5%
            ElseIf QTYValue.Contains("mm") Then
            ElseIf QTYValue.Contains("m") Then
                QTYValueNew = QTYValueNew * 1000 'convert m to mm
        Next
                For i = 1 To 1000
                    count = count + 1
                        Exit For
                Next
        Next
Message 12 of 24
Stakin
HI,Maybe you can use the UnitsOfMeasure Object,to convert tube length to database units
		Dim oUm As UnitsOfMeasure
		oUm = oDrawDoc.UnitsOfMeasure
			Dim  oValue As Double
			Try
				oValue=CDbl(QTYValue)
			Catch
				oValue = oUm.GetValueFromExpression(QTYValue, UnitsTypeEnum.kInchLengthUnits)
				Dim oPNum As Integer
				oPNum=Math.Ceiling(oValue*1.05/500)
				row.Item("QTY").Value = CStr(oPNum)
			End Try
        Next
Message 13 of 24
eladm
Hi
I think it work fine (test a few assembly's)
If in the drawing have more than 1 part list , the rule is only to the 1st Part list that inserted.
can the rule works for all the part lists in the drawing?
regards
Message 14 of 24
eladm
Hi
The rule works fine . but if the length of the parts change rerun the rule don't update the value
regards
Message 15 of 24
Stakin
Try this,all partlist will be changed.
and when model changed,run it, the partlist will update.
		Dim oUm As UnitsOfMeasure = oDrawDoc.UnitsOfMeasure
       	For Each oPartslist As Partslist In oSheet.PartsLists
			For Each row As PartsListRow In oPartslist.PartsListRows
				Try
					oValue = CDbl(QTYValue)
					row.Item("QTY").Value = CStr(oValue)
				Catch
				End Try
	        Next
		Next
Message 16 of 24
eladm
ERROR
Message 17 of 24
Stakin
please ensure it has "QTY" item in every partlist.
Message 18 of 24
eladm
Message 19 of 24
Stakin
which one is the partlists.item(1)?
Message 20 of 24
nstevelmans
Hi, try this for multiple Partslists
		For Each oPartslist In oSheet.PartsLists
        Next
        Next
                For i = 1 To 1000
                    count = count + 1
                        Exit For
                Next
        Next
				Next
