create a thousand separator in mass parameter
anuj16797
anuj16797
hii
I need to add a comma in the BOM in the mass of the part.
like if the mass of a part in an assembly is 5055 lbs then I need it to be shown as 5,055 lbs in the BOM.
@Curtis_Waguespack
Curtis_Waguespack
Hi @anuj16797
I don't know of a way to do this with built in Inventor settings, but I suppose you could create some custom code for this.
Here is a past post concerning creating a custom iProeprty to handle a format change for the mass.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/custom-properties/m-p/4808383#M48457
The syntax to add the thousands separator would be something like this:
Dim oValue As Double = 88888888888888
If oValue > 999 Then
	oMsg = oValue.ToString("###,###")
End If
MsgBox(oMsg)
If you have questions about how to implement this via code, I would suggest creating a new post on the customization forum and asking those questions,  and linking back to this topic for reference.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/bd-p/120
I hope this helps.
Curtis
anuj16797
it solved half of my problem but i still need your help.
As shown in the below image I need to calculate the unit weight of each part with a thousand separators and "NA" if the mass is less than one which is done.
but now I need the extended weight which is (UNIT WT * QTY) with a thousand separators and "NA" if the mass is less the one in unit wt.
If iProperties.Mass > 999 Then
	iProperties.Value("Custom", "Totalmass") = iProperties.Mass.ToString("###,###")
	iProperties.Value("Custom", "UNIT WT") = iProperties.Mass.ToString("###,###")
Else
	iProperties.Value("Custom", "UNIT WT") = Round(iProperties.Mass, 0)
End If
If iProperties.Mass < 1 Then
	 iProperties.Value("Custom", "UNIT WT") = "NA"
	 iProperties.Value("Custom", "EXT WT") = "NA"
End If
