Create a drawing list Excel
Message 1 of 10
We have all our drawing in a folder "drawings" per project file. Is it possible to have a code running and listing all these drawings in a excell as a drawing list? I would need the following custom iproperties in it: ACME_DRAWING, ACME_DESCRIPTION and the regular property PARTNUMBER.
Maybe something simular exist already?
Many Thanks!
Replies (9)
Message 2 of 10
Sergio.D.Suárez
Hello, try to configure this rule, use an excel template, you must correctly place the template path.
Then you must specify the name of the new excel file where you will save the list, as well as the path where the file will be saved.
'Example - Execute in assembly or part document
Dim Dirxlsx As String = "E:\Libro1.xlsx"    ''' Specify the excel template path
Dim osheet As String = "Sheet1"              ''' Specify the excel template sheet
Dim oExcelName As String = "Drawing_List" & ".xlsx"   ''' Specify the excel file name to save list
Dim processPath As String  = ThisDoc.Path     ''' "D:\Inventor\Planos en Inventor"   '''Specify the path of the find folder
'Open excel application
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open(Dirxlsx)
xlWorksheet = xlWorkbook.Worksheets.Item(osheet)
Dim row As Integer
row = 2                 ''' Indicate from which row the copying will start to excel
Dim drawings () As String = System.IO.Directory.GetFiles(processPath,"*.idw",System.IO.SearchOption.AllDirectories)
For Each drawing As String In drawings
 On Error Resume Next
	Dim oDoc As Document = ThisApplication.Documents.Open(drawing, False)
	xlWorksheet.Range("A" & row).Value = oDoc.DisplayName
	xlWorksheet.Range("B" & row).Value = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
	xlWorksheet.Range("C" & row).Value = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("ACME_DRAWING").Value
	xlWorksheet.Range("D" & row).Value = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("ACME_DESCRIPTION").Value
	oDoc.Close
	row=row+1
Next
xlWorksheet.Columns("A:Z").AutoFit
MessageBox.Show(oExcelName , "Export to")
xlWorkBook.SaveAs(ThisDoc.Path & "\" & oExcelName)' The excel file will be saved in the location of the assembly file
xlWorkbook.Close(True)
xlApp.Quit
 I hope it helps you solve your problem.
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 10
Hello thanks for the start, but I was thinking of looping through the drawing folder instdead of an assembly. There might be more assemblies in the project, but there is only 1 drawing folder with all the drawings in it.
(I might copy the models iproperties to the drawing iproperties if needed)
Projectpath\drawings\....
Message 4 of 10
Sergio.D.Suárez
In the example I gave you, the assembly part or drawing is only to activate the rule, not to use it itself, what you need is to configure the rule, so that it looks in the folder requested all the drawings (I do not know which is the route of the folder that contains drawings)
This rule looks only for drawing files, it does not look for assembly files. and will return the properties of those drawings in an excel table.
You must change the line
and place your path of drawing files, for example
Dim processPath As String = "D:\Inventor\Drawings Files"
'Example
Dim row As Integer
	oDoc.Close
	row=row+1
Next
xlWorkBook.SaveAs(processPath & "\" & oExcelName)
xlApp.Quit
 Excuse me if I have not been clear. regards
Mechanical Designer
Message 5 of 10
@Sergio.D.Suárez
Thank you very much. Would it be difficult to change the way the iproperties are collected? I don't have the iproperties in my drawing, but only in the model that is used in the drawing...? My titleblocks also get filled in with the models iproperties.
Message 6 of 10
Sergio.D.Suárez
No, I think it's not very difficult once you open the drawing in false mode, you would have to access the specific view and then the view model
you must specify the sheet and the view where you want to reference (As you place a piece by plane there is no problem, I will put the number 1)
Dim oView As DrawingView
oView = oDoc.Sheets(1).DrawingViews.Item(1)  ' specify the sheet and the view where you want to reference
oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument ' Document reference of part or assembly in drawing view
oViewModelName = oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName 'Document name of part or assembly in drawing view
ACME_DESCRIPTION= iProperties.Value(oViewModelName, "Custom", "ACME_DESCRIPTION")' Iproperty of part or assembly in drawing view
I hope it will be helpful for you to solve your problem
Mechanical Designer
Message 7 of 10
This should come inside the For each loop?
	PTN_DRAWING = iProperties.Value(oViewModelName, "Custom", "PTN_DRAWING")' Iproperty of part or assembly in drawing view
	PTN_DESCRIPTION_NL= iProperties.Value(oViewModelName, "Custom", "PTN_DESCRIPTION_NL")' Iproperty of part or assembly in drawing view
	xlWorksheet.Range("C" & row).Value = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("PTN_DRAWING").Value
	xlWorksheet.Range("D" & row).Value = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("PTN_DESCRIPTION_NL").Value
	oDoc.Close
	row=row+1
Next
Message 8 of 10
Sergio.D.Suárez
	xlWorksheet.Range("A" & Row).Value = oDoc.DisplayName
	xlWorksheet.Range("B" & Row).Value = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value ' Part number of drawing document
	xlWorksheet.Range("C" & Row).Value = PTN_DRAWING
	xlWorksheet.Range("D" & Row).Value = PTN_DESCRIPTION_NL
	oDoc.Close
	Row=Row+1
Next
 I should try something like this, I have not tried it, I will never probe a view in false document opening mode
Note that the property of part number refers to the drawing file, if you need the property of the part or assembly, you should apply a criterion similar to the one described above.
Surely there must be alternative paths for what you are looking for, it occurred to me to go here, maybe some of the experts have a better solution to the problem described
Mechanical Designer
Message 9 of 10
After all, I don't think this is the good way (cause of false document open mode?) because other rules that are set to run on "document open", fail and are prohibiting this rule to run... it gives errors...
So if other suggestion pop up...?
Message 10 of 10
Sergio.D.Suárez
If you want to try not to open in false mode, try modifying this line, if the iproperties are from the drawing document, put false to not have the need to open it, now dealing with the iproperties of the view model, you may need to open each document normally and that the program then closes it alone
Dim oDoc As Document = ThisApplication.Documents.Open(drawing, True)
Mechanical Designer
