Create 2D sketch in IDW using API
Message 1 of 1
I need to create a 2D sketch from parameters stored in a CSV file for an object that would be laser cut. The code sample I have does not fail, but results in nothing. I'm running this code in a module withing a larger project which is why I'm calling variables and don't have them declared.
Public Sub Retainer(CompDef, TG, m_inventorApp, Sketch, ID)
        Dim DrawDoc = m_inventorApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, m_inventorApp.FileManager.GetTemplateFile(DocumentTypeEnum.kDrawingDocumentObject))
        Dim Sheet As Sheet = DrawDoc.ActiveSheet
Sheet.Border.Delete() Sheet.TitleBlock.Delete() Dim Width As Double = 24 * 2.54 Dim Height As Double = 12 * 2.54 Sheet.Size = DrawingSheetSizeEnum.kCustomDrawingSheetSize Sheet.Width = Width Sheet.Height = Height Sketch(1) = CompDef.Sketches.Add(CompDef.WorkPlanes(3)) Dim Retainer As SketchCircle = Sketch(1).SketchCircles.AddByCenterRadius(TG.CreatePoint2d(0, 0), ID / 2) DrawDoc.Update() End Sub
Replies (0)
